Re: Dual Zone Climate control not working –
30-10-2018,02:46 PM
You need to check the temp sensors fitted in the ducts just behind the outlets. These will monitor the temps and tell the control panel what the temp of air is at the outlet. If you pull the side fuse box access panel off you will see the 2 pin temp probe fitted into the black vent duct.
Have you scanned the car for any fault codes?
RS6 Performance Ascari Blue, Carbon Ceramics Brakes and lots more.
A6 BiTdi Avant MTM
Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds,High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
