Suddenly I got in my Golf Plus 2007 5m1 1.4 TSI 140PH, this ABS fault:
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
many forums advises to check the fuses in that box beside the battery, but that doesn't solve it.
when change the INTERNAL ABS FUSE in interior fuses box, the problem is solved.
please note that, that fuse caused the problem is not burned or cut, and doesn't show any damage sign, maybe is not stable that what is caused the problem.
good day
