Thread: Abs sensor effecting other modules/systems?
  1. Abs sensor effecting other modules/systems?
    Mar 2016
    ipswich, uk
    Hi. Had some errors pop up after replacing a door window ecu. After getting most reset by a garage i still have abs, auto hold, directional lights, auto start/stop, esp, steering assist and parking brake errors. including optical parking assist is unavailable.
    Error codes
    3842 rpm sensor believe its the rear right abs sensor.
    01316 steering assist abs control module
    0112300 xeon data bus error
    Ive been told the abs sensor will effect the parking assist/ auto hold
    So my question will an ABS sensor cause/effect all the other systems/ all the other fault codes?
  2. Re: Abs sensor effecting other modules/systems?
    Mar 2016
    ipswich, uk
    I guess ive answered it myself. Yes it does. Replaced sensor and all errors have gone.
  3. Re: Abs sensor effecting other modules/systems?
    Sep 2015
    North West
    Yep. ABS sensor turns the dash into Christmas tree lights.
    Effects auto hold, cruise control, tyre pressure sensors and all sorts. Easy fix thankfully, did mine last year.
  1. A how-to with some VAG-COM modules
    By Marco34 in forum VCDS - General Questions
    Last Post: 10-11-2016, 11:59 PM
  2. Question Difference between modules??
    By djt1954 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-03-2016, 07:30 AM
  3. How do i know if i need to log in to modules?
    By dan.taylor.1 in forum VCDS - General Questions
    Last Post: 15-09-2011, 08:46 PM
  4. Help: Cannot communicate with modules
    By johnwintle in forum VCDS - Help Requests
    Last Post: 30-10-2009, 09:47 PM
  5. can't read modules
    By garnier in forum VCDS - Help Requests
    Last Post: 17-09-2009, 10:45 PM
