Thread: 3.0tdi no power to injectors, no fault code then injector disconnected A6/C6 3.0TDI
  1. 3.0tdi no power to injectors, no fault code then injector disconnected A6/C6 3.0TDI
    Oct 2014
    TAUNTON . SOMERSET
    hello to all memebers,
    I have 2006 a6/c6 3.0tdi BMK manual, she is not starting just cranking, vcds gives no faults related to this. I disconnected injector cables but gives me no fault too?.
    I can prime fuel pump by doing output test, installed to little filters in place of original filter to see fuel flow and return live ,cleaned grounds and lives, checked fuses, checked ecu for water all clean and dry. also hiwire fuel pump just to see it pumping all good, car start with easy start spray, but stalls instantly if spray stoped. injectors calibration from ecu is
    cyl1 -4 0 1
    cyl2 -2 12 2
    cyl3 0 0 2
    cyl4 0 2 0
    cyl5 -4 0 0
    cyl6 0 4 0
    im out of clues what to do next? thank you for any input
    injectors and fuel pump have no power to them with ignition on
  2. Re: 3.0tdi no power to injectors, no fault code then injector disconnected A6/C6 3.0TDI
    1840 Post(s)
    Do you have fuel pressure from the high pressure pump?
  3. Re: 3.0tdi no power to injectors, no fault code then injector disconnected A6/C6 3.0TDI
    Oct 2014
    TAUNTON . SOMERSET
    hi CRASHER,
    could you explain how to do that?
    then cranking requested was something like 348bar and actual climbed to something similar, so I beleve so. I installed transparent filter on feed and one filter on return hoses from original fuel filter, then hiwire fuel pump in the tank, then feed filter was with diesel I started to crank engine then return filter filled up with diesel but still not starting. no voltage to injector wires or fuel pump in the tank.
  4. Re: 3.0tdi no power to injectors, no fault code then injector disconnected A6/C6 3.0TDI
    Jul 2013
    76 Post(s)
    There was a post on here recently that had a similar issue which was the crankshaft sensor not seeing a signal due to a damaged flywheel.
    Dan
    2009/2010 2.0 TDIe SE
  5. Re: 3.0tdi no power to injectors, no fault code then injector disconnected A6/C6 3.0TDI
    1840 Post(s)
    Quote Originally Posted by Martynas26 View Post
    hi CRASHER, could you explain how to do that?
    In measuring blocks which you have done and it seems correct
  1. Q7 3.0TDi 2011 ECU/Throttle Circuit fault plus oil/injector seals
    By colbry in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 17-05-2018, 03:53 PM
  2. fault code p2008 on a 3.0tdi, help please
    By white.akita in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 24-07-2015, 06:30 PM
  3. Please Help 2005 2.0tdi fault code po299
    By ifsot in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-12-2013, 10:52 PM
  4. 3.0Tdi - P0183 fault code
    By seventh-heaven in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-09-2011, 11:12 PM
  5. Exhaust emmision fault code 2.0tdi
    By ralmeyda in forum Golf MK5 - 2004 - 2009
    Last Post: 16-08-2009, 12:54 PM
