Thread: HELP - Engine turns but wont start, 3 beeps, brake warning.
Results 1 to 9 of 9
  1. Question HELP - 1.9TDI Engine turns but wont start, 3 beeps, brake warning.
    Dec 2008
    Just got in my car this morning (B6 1.9TDI) and turned the key. It turned over like normal but nothing fired. After a second or so, a brake warning light appeared and the car made 3 beeps.
    I had been noticing some occasional odd behaviour for a few weeks now, its hard to explain but sometimes I would turn the key and nothing would happen. It wouldn't turn or anything, but if I turned it off, waited a moment and tried again it would start. Not sure if these issues are related.
    Anyway, I just made a video of the issue I described. Hopefully its of use.
    Note, the first beep relates to a bulb which is blown.
    Audi A4 b6 won't start - YouTube
  2. Re: HELP - 1.9TDI Engine turns but wont start, 3 beeps, brake warning.
    scotland
    39 Post(s)
    Its the crank angle sensor/engine speed sensor G28. If you try to start the engine watch the rev counter needle if it doesn't move this confirms the sensor.
    Brake warning will always appear after several non-starts, it is a red herring and should be disregarded.
    Sent from my ANE-LX1 using Tapatalk
  3. Re: HELP - 1.9TDI Engine turns but wont start, 3 beeps, brake warning.
    scotland
    39 Post(s)
    A fault code read would help.
  4. Re: HELP - 1.9TDI Engine turns but wont start, 3 beeps, brake warning.
    Dec 2008
    Thanks for this info, but as the video shows the rev counter needle does move a little bit as its turning over (approx 200 rpm according to the dial)...
  5. Re: HELP - 1.9TDI Engine turns but wont start, 3 beeps, brake warning.
    scotland
    39 Post(s)
    That's why I added a fault code read would help in the next post.
  6. Re: HELP - 1.9TDI Engine turns but wont start, 3 beeps, brake warning.
    scotland
    39 Post(s)
    Found this post regarding crank speed which I thought was a little slow.
    I just finished a search back to 1999, and found nothing really, but I did come across one person (ymz) saying the same thing: under 250 and the ECU cuts fueling...well that doesn't make sense because it starts, albeit a little slow (4-6 seconds cranking).
  7. Re: HELP - 1.9TDI Engine turns but wont start, 3 beeps, brake warning.
    20 Post(s)
    604 Post(s)
    Looks like it could do with a service as well, that is part of the beeping. The cranking speed needs to be 280 but above 200 rpm usually gets them going eventually so yes, a code read is number 1 step and then check the cranking rpm in measuring blocks.
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
  8. Re: HELP - 1.9TDI Engine turns but wont start, 3 beeps, brake warning.
    Dec 2008
    Thanks.
    So before I get a mechanic should I try and jump start it with a friends battery?
    I only bought a new battery last year so will be very surprised if it was the battery...
  9. Re: HELP - 1.9TDI Engine turns but wont start, 3 beeps, brake warning.
    20 Post(s)
    604 Post(s)
    DO NOT use jump leads! Recharge the battery or use a proper jump pack.
  1. Turns over but wont start
    By Biggzy Knight in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-07-2017, 12:51 PM
  2. 99 tdi no dash lights turns over wont start
    By pg339 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-12-2013, 04:07 PM
  3. car turns-over but wont start ?
    By v8slugger in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-02-2010, 03:39 PM
  4. Non starter, engine turns alright but wont start A4 1998 1.6 petrol
    By kobby in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-03-2008, 10:16 PM
  5. Car turns over but wont start...
    By kjopen in forum Golf MK3 - 1993 - 1999
    Last Post: 08-03-2008, 04:06 AM
