Thread: 1998 Audi Cabriolet Stereo upgrade
  1. 1998 Audi Cabriolet Stereo upgrade
    Dec 2010
    London, UK
    Hi all,
    Am in the process of upgrading the Audi Delta stereo to a flip out screen one. A couple of questions that I'm hoping someone here may be able to help me with as this isn't as straight forward as I thought it'd be!
    1. The stereo is either all on or all off. When testing normally, with the accessory power removed the screen is supposed to go down. However, in this it just stays up as the power is completely cut. Is there any way I could wire it so that it has a permanent power supply to the stereo when it's off so the screen will go down at least?
    2. The stereo adaptors that I got do not seem to fit this model at all even though it was advertised for this make. Can someone point me in the right direction?
    The current install has these gaps:
    The adaptors I got just don't fit at all:
    If I put this in before sliding the stereo in, the stereo won't slide in. And then I can't fit them after the stereo is in (and before I put the stereo surround on).
    Any advice would be greatly appreciated!!
  2. Re: 1998 Audi Cabriolet Stereo upgrade
    Dec 2010
    London, UK
    Resolved point 1 - the PC9-409 adaptor needs some wires changing to work in an Audi cabrio. First the speaker cables need to be changed so that the front speakers will work and then the Red and Yellow cables need swapping as well.
    Point 2 still an issue - any help would be appreciated
  1. Question Audi A4 cabriolet b7 mmi 2g Tv upgrade
    By sbtech in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-10-2014, 02:10 PM
  2. Upgrade stereo in 2005 A4 Cabriolet
    By CharlieG123 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-01-2011, 12:56 PM
  3. Question Audi Cabriolet 1998 Intermitant fuel gauge...
    By tommivercetti in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 08-11-2009, 11:12 PM
  4. Please Help 1998 audi cabriolet problems
    By a1alan in forum 80 - 90
    Last Post: 31-07-2008, 08:04 AM
  5. 1998 audi cabriolet electric hood sticking
    By jazz21 in forum 80 - 90
    Last Post: 09-12-2007, 06:25 PM
