Thread: Parasitic drain from fuel pump circuit on 1.6FSI
  1. Parasitic drain from fuel pump circuit on 1.6FSI
    Aug 2018
    Trying to fix a problem on my dads 2004 Golf 1.6 FSI. He had a flat battery, everything checked out on the charge side, but there was a parasitic drain I traced to the fuel pump module circuit. You could hear it run with ignition off. Remove 15A blue fuse (F27?) and pump stopped. So he has been using it like that - fuse in, drive, stop, fuse out. Not healthy.
    I tested the fuel pump and 1ohm, but I do not know what or how to test for a ground or fault - any suggestions on how to check the module - it has no heat or burn marks and I understand that is when they fail. But I wonder if that is the problem.
    He did say he reversed into/over something back nearside - that was the day it happened, but I cannot see any marks underneath or what it could have even pushed to cause a ground.
    EML came on yesterday and a scan showed P0091 which cleared ok and I assume was linked. I need to find the code we got for the fuel pump to ground and post as he sent me an email with partial scan.
    Also have the interior lights go, code 00059 terminal 30 (interior lights) - 012, electrical fault in circuit - but the 7.5A fuse is fine.
  2. Re: Parasitic drain from fuel pump circuit on 1.6FSI
    Aug 2018
    I now have the code - 01259 - Fuel Pump Relay (J17) 009 - Open or Short to Ground
    So, fuel pump is off when fuse is out. But works when I take both 449 relays out. Does that mean there is a wiring fault to ground/live and not the relays?
    Any advice on how to test would be great, electrics not my strong point
  3. Re: Parasitic drain from fuel pump circuit on 1.6FSI
    1840 Post(s)
    I would say it is the highly unreliable and multiply revised fuel pump control unit, VW part number 1K0 906 093 J and costs £116.62
  4. Re: Parasitic drain from fuel pump circuit on 1.6FSI
    Aug 2018
    Thanks Crasher - I need to get my notifications updated as I missed this. I have ordered one.
    Now I need to work out what is happening with the interior lights. The auto electrician said it might be the main control unit! deep joy.
  1. Please Help Coolant Pump v50 open circuit
    By Raflus in forum A8 - S8 - V8
    Last Post: 11-03-2015, 08:19 PM
  2. Fuel pump primary circuit malfunction?
    By a3aud11 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-10-2014, 04:45 PM
  3. Circuit Diagram of Central locking pump - Part Number - 8L0 862 257 G
    By xgimp in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 02-06-2009, 07:07 PM
  4. Question Circuit board - A4 Central locking pump
    By Griff56 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-08-2008, 11:18 PM
  5. Intermittent blowing fuse on fuel pump circuit
    By Clavdivs in forum Polo - Derby - Lupo - Fox
    Last Post: 02-02-2007, 04:01 PM
