Thread: Flashing Glow Plug then DPF light on - regain failed to clear?
  1. Flashing Glow Plug then DPF light on - regain failed to clear?
    2009 Audi A3 1.9 TDI. 175k
    First I had a flashing glow plug light that was intermittent. I did a fault code read and it showed:
    001350 - Sensor 1 for Exhaust Temp Bank 1 (G235)
    P0546 - 000 - short to plus - Intermittent
    So I assume it needs a new sensor, but before I could replace it the DPF light came on.
    I trued a region but no joy - could the faulty sensor be preventing a regen?
    Thanks in advance
  2. Re: Flashing Glow Plug then DPF light on - regain failed to clear?
    Ok I managed to force a regen of the DPF - it looks like it hadn't regex'd in a while but it has cleared the def light and reduced the loading to 10% (from 80%!!).
    Also confirmed the exhaust gas sensor is faulty as it would read 400deg C and then go full scale to 950 deg c and hold it for a while and then drop suddenly back to 400 deg C.
    Question - how difficult is it to replace the exhaust gas sensor? Looks like i need a crows socket? Any tips?
  3. Re: Flashing Glow Plug then DPF light on - regain failed to clear?
    Aug 2018
    Hi, can I ask how you got conformation the EGT was reading 400 - 950? I have a similar issue with EGT sensor 4 bank 1 on my Caddy and my DPF light came on but cannot do a regen. I had to take it to a garage who is changing the sensor (said it was def dead, not wiring or short) but I’d like to keep the old one to learn from.
    I also would like to know how tricky they are - I have seen a post from Crasher warning to go gently as the stainless body can get stuck.
  1. Flashing glow plug light.
    By rplc1976 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-11-2014, 08:18 AM
  2. Mk4 glow plug light flashing
    By wessex84 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-01-2011, 03:57 PM
  3. Please Help Glow plug light flashing
    By sunshinekid in forum Octavia
    Last Post: 02-02-2010, 12:29 AM
  4. Flashing Glow Plug Light??
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-11-2009, 09:49 PM
  5. a3 flashing glow plug light
    By yalittlebeauty in forum Audi A3 - Archive Topics
    Last Post: 05-02-2009, 10:57 AM
