Thread: 2004 a3 rear n/s light
  1. 2004 a3 rear n/s light
    May 2014
    bradford, west yorkshire
    my rear tail light as stopped working, changed the bulb, checked the bulb holder still not working cant find which fuse controls it can anyone help
  2. Re: 2004 a3 rear n/s light
    1836 Post(s)
    They are not fused, the lights are computer controlled by the central electrics units so you would need a suitable diagnostic system to interrogate this and use functions such as output test to determine what is wrong. Have you tried just plugging in the other unit to see if it works?
  3. Re: 2004 a3 rear n/s light
    May 2014
    i swapped the bulb holders over and it wouldnt work on the o/s fiddle about a bit more and it came back to life, i have vcds and when i scan it i cannot scan module 9 or 46 central electric and central convenience it just comes up with to many communication errors
  4. Re: 2004 a3 rear n/s light
    1836 Post(s)
    You need to get into group 09 and if you can’t it means that the CAN BUS system has a problem or you are using a non approved VCDS dongle.
  1. Question How to find out why rear fog light not working in A6 Allroad 2004
    By mikejammey in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-03-2018, 11:09 PM
  2. Replies: 10
    Last Post: 02-01-2015, 05:08 PM
  3. 2004 A6 3.0 TDI Quattro rear fog light and reverse light problem
    By Chris1965 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-01-2013, 01:30 PM
  4. Question Sharan 2004-2010 rear light cluster
    By JezB in forum Touran - Sharan - Caravelle
    Last Post: 11-11-2012, 01:28 PM
  5. 2004 A3 2.0 tdi rear RH side tail light no voltage
    By trickyonethis in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-02-2011, 03:17 PM
