Thread: Throttle body (ASV) & cooling fan problem
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Throttle body (ASV) & cooling fan problem
    Oct 2017
    Halifax, West Yorkshire
    22 Post(s)
    hello everyone, so I had the following codes below:
    005000 - Control Module Malfunction - DBW Throttle Monitoring
    P1388 - 000 - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 255
    Mileage: 329791 km
    Time Indication: 0
    Date: 2012.12.27
    Time: 23:16:42
    Freeze Frame:
    RPM: 2300 /min
    Speed: 120.0 km/h
    Voltage: 13.91 V
    Voltage: 1.672 V
    Voltage: 0.836 V
    Torque: 160.0 Nm
    Bin. Bits: 0000000
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 64
    Reset counter: 255
    Mileage: 329791 km
    Time Indication: 0
    Date: 2012.12.27
    Time: 23:16:42
    Freeze Frame:
    RPM: 2346 /min
    Speed: 120.0 km/h
    Load: 29.0 %
    Bin. Bits: 0000000
    Inj. Quantity: 0.0 mg/str
    Hex Value: 0xFF02
    Hex Value: 0xFF01
    006472 - Control Module 2 for Cooling Fan
    P1948 - 000 - Output Short Circuit - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 329239 km
    Time Indication: 0
    Date: 2012.12.23
    Time: 15:04:56
    Freeze Frame:
    RPM: 2093 /min
    Speed: 53.0 km/h
    Temperature: 44.1°C
    Temperature: 81.9°C
    Temperature: 26.1°C
    Lambda: 26.0 %
    Lambda: 0.0 %
    Readiness: 0 0 0 0 0
    the problem got worse when the car would no longer start even though it was working perfectly fine few hours before. The belief was that the fuse was blown that both the anti shudder valve and cooling fan uses and the ASV was left in the closed position causing the engine to not start. I then looked for the fuse in the engine compartment as that's where most engine management fuses are. I couldn't allocate the specific fuses to I removed all engine management fuses and replaced them. I then tried to start the car and it didn't work so I then removed the ASV. Hoping I would do an output test to see whether the valve operates I then hooked up vcds and I had bigger problems occur.
    Prior to removing the ASV I removed four 10 amp fuses in the engine bay and since then when I would put the key in ignition the instrument cluster would make a ticking noise. fast forward removing the ASV I hooked up vcds to test the valve and it said engine control module unreachable. Now ive hooked it up after changing every single engine management fuse in the engine bay and left the battery disconnected and now multiple control modules are unreachable. my vcds is genuine fyi.
    01-Engine -- Status: Cannot be reached 1100
    15-Airbags -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: Malfunction 0010
    Address 01: Engine
    Cannot be reached
    Address 03: ABS Brakes
    Cannot be reached
    Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
    Part No SW: 5K0 907 044 HW: 5K0 907 044
    Component: Climatronic 120 0202
    Revision: 00002001
    Coding: 0000000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Climatronic A01001
    ROD: EV_ClimaAutoBasis_VW36.rod
    VCID: 68894499A2F1F897D97-803C
    3 Faults Found:
    13701376 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    [Motorsteuergerät - kein Signal/Kommunikation]
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 6
    Reset counter: 169
    Mileage: 330023 km
    Date: 2018.08.11
    Time: 13:02:01
    13701888 - Function Restriction due to Faults in Other Modules
    U1113 00 [008] - -
    [Motorsteuergerät - bitte Fehlerspeicher auslesen]
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 329239 km
    Date: 2018.08.03
    Time: 15:05:01
    9481988 - Air Quality Sensor
    B10AF 04 [008] - Internal System Fault
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 254
    Reset counter: 209
    Mileage: 261162 km
    Date: 2015.12.16
    Time: 00:21:19
    Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
    Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
    Component: Bordnetz-SG H54 2602
    Revision: 00H54000 Serial number: 00000008533969
    Coding: E0800F8B0004100047970F00170000000008FF475C40017C17 0000000000
    Shop #: WSC 05124 000 00000
    VCID: 3333E3F5A7374B4FBC5-8066
    Subsystem 1 - Part No: 3C8 955 119 A Labels: 1KX-955-119.CLB
    Component: Wischer 300408 022 0602
    Coding: 00046997
    Shop #: WSC 05124
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 250608 054 0402
    Coding: 00209133
    Shop #: WSC 05124
    5 Faults Found:
    02394 - Parking Light Left Front (M1)
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Reset counter: 192
    Mileage: 312190 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 11.80 V
    ON
    ON
    OFF
    OFF
    ON
    00984 - Left Tail Light (M4)
    Freeze Frame:
    Fault Status: 00111100
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 196
    Mileage: 323203 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 14.15 V
    ON
    ON
    OFF
    OFF
    ON
    01049 - Supply Voltage Term 50
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 169
    Mileage: 330023 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 11.75 V
    OFF
    ON
    ON
    OFF
    OFF
    01314 - Engine Control Module
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 169
    Mileage: 330023 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 11.80 V
    ON
    ON
    OFF
    OFF
    OFF
    00059 - Terminal 30 for Interior Lighting
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 209
    Mileage: 330023 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Address 15: Airbags
    Cannot be reached
    Address 16: Steering wheel
    Cannot be reached
    Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
    Part No SW: 3C8 920 970 A HW: 3C8 920 970 A
    Component: KOMBI H19 0023
    Serial number: 00000000000000
    Coding: 440F00
    Shop #: WSC 05311 115 00000
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
    VCID: 2A0DFE917C7D0A870F3-807E
    1 Fault Found:
    12648448 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    [Steuergerät für Motor: keine Kommunikation]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 13
    Reset counter: 209
    Mileage: 330023 km
    Date: 2018.08.11
    Time: 13:01:57
    Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
    Part No SW: 3C0 907 530 H HW: 3C0 907 951
    Component: J533__Gateway H13 0142
    Revision: H13 Serial number: 2600P085300F98
    Coding: F9807F060002029003
    VCID: 26150AA164E52EE72BB-8072
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 169
    Mileage: 330023 km
    Time Indication: 0
    Date: 2013.01.01
    Time: 13:01:59
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
    Component: IMMO 042 0383
    Revision: 00042000 Serial number: VWZCZ000000000
    Shop #: WSC 00400 210 83203
    VCID: 392FD1DD855BB11F769-806C
    Subsystem 1 - Part No: 3C0 905 861 J
    Component: ELV 029 0380
    3C0905861J ELV 029 0380
    2 Faults Found:
    01176 - Key
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 169
    Mileage: 330023 km
    Time Indication: 0
    Date: 2013.01.01
    Time: 00:00:47
    01176 - Key
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 1
    Fault Frequency: 14
    Reset counter: 169
    Mileage: 265356 km
    Time Indication: 0
    Date: 2010.06.12
    Time: 18:01:19
    Address 42: Door Elect, Driver
    Cannot be reached
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 C
    Component: EPS_ZFLS Kl. 207 2301
    Revision: 00H15000
    Shop #: WSC 02069 000 90108
    VCID: 2A0DFE9170FD0A870F3-807E
    5 Faults Found:
    00750 - Warning Lamp
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 219
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Voltage: 0.00 V
    PD
    Temperature: -70.0°C
    RPM: 0 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Count: 0
    16347 - Control Module - EEPROM Error
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Freeze Frame:
    Fault Status: 00100101
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 50
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Voltage: 0.00 V
    PD
    Speed: 0.0 km/h
    Torque: 0.0 Nm
    Torque: 0.000 Nm
    Term 15 Off
    01316 - ABS Control Module
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 9
    Reset counter: 211
    Mileage: 329247 km
    Time Indication: 0
    Date: 2012.12.24
    Time: 17:10:15
    Freeze Frame:
    Voltage: 13.63 V
    DU
    Temperature: 58.0°C
    RPM: 781 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Count: 0
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 169
    Mileage: 330023 km
    Time Indication: 0
    Date: 2013.01.01
    Time: 13:02:01
    Freeze Frame:
    Voltage: 11.88 V
    DU
    Temperature: 13.0°C
    RPM: 1498 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Count: 0
    00778 - Steering Angle Sensor (G85)
    000 - - - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 330023 km
    Time Indication: 0
    Date: 2013.01.01
    Time: 00:00:34
    Freeze Frame:
    Battery Volts: 12.0 V
    PD
    Temperature: 18.0°C
    Count: 2
    Steering Angle: 0.00°
    Count: 0
    SteerAng n.Init
    Address 46: Central Conv.
    Cannot be reached
    Address 52: Door Elect, Pass.
    Cannot be reached
    Address 53: Parking Brake
    Cannot be reached
    Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 3C8 035 195 HW: 3C8 035 195
    Component: Radio RCD510 036 0130
    Revision: 00000001 Serial number: VWZ1Z3H3254141
    Coding: 0500040004
    Shop #: WSC 05314 000 00000
    VCID: 65974DAD5563E5FFE21-8030
    1 Fault Found:
    00874 - Treble Speaker Front Left (R20)
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 169
    Mileage: 330023 km
    Time Indication: 0
    Date: 2012.12.31
    Time: 19:23:10
    Address 62: Door, Rear Left
    Cannot be reached
    Address 72: Door, Rear Right
    Cannot be reached
    End----(Elapsed Time: 00:37, VBatt start/end: 11.9V/11.9V. VIgn 0.0V)------
    I believe that this may be caused by fuses dying but I cant get my head around how a common ASV can go from a small issue to a most control modules malfunctioning. I need to test multiple wires and control modules to see if they are getting power but I don't know how this is done with a multimeter. I also believe that the instrument cluster ticking maybe due to a fuse or relay positioned behind the cluster that's gone bust. If anyone can help me that would be great. I feel like its time to call the diagnostic tech, this has gone way beyond me.
  2. Re: Throttle body (ASV) & cooling fan problem
    Oct 2017
    22 Post(s)
    okay so huge progress has been made. it turns out that due to having someone else help me swap out fuses they misplaced one of them and the ecu therefore did not communicate. The ecu is now communication, output tests on both cooling fans and ASV have been performed and they are both working. the noise from the instrument cluster has also disappeared. I have cleared the engine codes and now I'm getting no codes which is actually bad as I have no indication as to what is wrong. The car still does not start. I will be testing the fuelling system and if it still doesn't work then I don't know what to say really. I will check ground connections for any corrosion and starter motor. Any suggestions are welcome :-)
  3. Re: Throttle body (ASV) & cooling fan problem
    1837 Post(s)
    Can you do another full scan and post it, do this with a battery charger attached and after allowing it to fully charge.
  4. Re: Throttle body (ASV) & cooling fan problem
    Oct 2017
    22 Post(s)
    sorry for the late reply, I did as you said but didn't manage to get the battery full overnight, however I did do the scan with charger attached. I also did a voltage drop test on the starter motor and changed some of the relays with another car that had the same relays. the voltage between the starter motor and battery were the same, I did this by positive on starter, negative on battery. I then did a voltage drop test and got 00.75V and 00.52V respectively. At the time of doing this, battery was at a poor 11.70V. when I place the key in, ignition comes on, I then fully insert it and hear some form of click from the engine bay. I couldn't turn the engine, I didn't have the 12 point socket for the crank. What size is the crank socket size? The relays I changed were the large HHZ3, KL30 and horn, in the engine bay I changed R2. Some pics below of relay and starter.
    Dropbox - Passat CC - Simplify your life
    Wednesday,15,August,2018,11:11:22:08765
    VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
    Data version: 20180518 DS287.1
    Ross-Tech: Home
    VIN: WVWZZZ3CZ9E510398
    Mileage: 330020km-205064mi
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
    VIN: WVWZZZ3CZ9E510398 Mileage: 330020km-205064miles
    01-Engine -- Status: Malfunction 1010
    Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
    Part No SW: 03L 906 022 BL HW: 03L 907 309
    Component: R4 2,0L EDC 0001SG 6221
    Revision: --H01--- Serial number: VWZCZ000000000
    Coding: 0000072
    VCID: 70B92CF996A13057817-8024
    1 Fault Found:
    000258 - Mass Air Flow Sensor (G70)
    P0102 - 000 - Signal too Low - MIL ON
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 330023 km
    Time Indication: 0
    Date: 2013.01.05
    Time: 00:09:14
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Voltage: 10.64 V
    Load: 100.0 %
    Load: 100.0 %
    Mass Air / Rev.: 510.0 mg/str
    Mass Air / Rev.: 0.0 mg/str
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
    Part No SW: 3C0 614 109 P HW: 3C0 614 109 P
    Component: J104 C4 440 V2 0011
    Revision: --025--- Serial number: 00000785785867
    Coding: 0003346
    Shop #: WSC 05311 000 00000
    VCID: 2B03FB957F07138FF45-807E
    4 Faults Found:
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 19
    Reset counter: 169
    Mileage: 330023 km
    Time Indication: 0
    Date: 2013.01.02
    Time: 13:01:59
    Freeze Frame:
    Speed: 0.0 km/h
    Hex Value: 0x0000
    Voltage: 11.75 V
    Bin. Bits: 00011111
    Count: 154
    Hex Value: 0x0000
    00283 - ABS Wheel Speed Sensor; Front Left (G47)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 192
    Mileage: 328788 km
    Time Indication: 0
    Date: 2012.12.16
    Time: 22:37:11
    Freeze Frame:
    Speed: 111.0 km/h
    Hex Value: 0x00D1
    Voltage: 13.75 V
    Bin. Bits: 00011111
    Count: 28
    Hex Value: 0x0000
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 192
    Mileage: 328788 km
    Time Indication: 0
    Date: 2012.12.16
    Time: 22:37:11
    Freeze Frame:
    Speed: 111.0 km/h
    Hex Value: 0x00D1
    Voltage: 13.75 V
    Bin. Bits: 00011111
    Count: 28
    Hex Value: 0x0000
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 192
    Mileage: 328788 km
    Time Indication: 0
    Date: 2012.12.16
    Time: 22:37:11
    Revision: 00002001
    Coding: 0000000000
    3 Faults Found:
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 7
    Reset counter: 209
    Mileage: 330023 km
    Date: 2018.08.12
    Time: 13:02:01
    U1113 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 329239 km
    Date: 2018.08.04
    Time: 15:05:01
    B10AF 04 [009] - Internal System Fault
    Freeze Frame:
    Fault Priority: 3
    Reset counter: 169
    Mileage: 261162 km
    Date: 2015.12.17
    Time: 00:21:19
    Coding: 00046997
    Shop #: WSC 05124
    Coding: 00209133
    Shop #: WSC 05124
    5 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 192
    Mileage: 312190 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 11.80 V
    ON
    ON
    OFF
    OFF
    ON
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 196
    Mileage: 323203 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 14.15 V
    ON
    ON
    OFF
    OFF
    ON
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 173
    Mileage: 330023 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 11.75 V
    OFF
    ON
    ON
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 209
    Mileage: 330023 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 11.80 V
    ON
    ON
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 209
    Mileage: 330023 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.30 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
    Component: J234__301 VW10 HI 1815
    Revision: 19013000 Serial number: 0039DPBTGKZW
    Coding: 0012337
    VCID: 3B23CBD58F67830F645-806E
    Subsystem 1 - Serial number: 6333FTS638111258
    Subsystem 2 - Serial number: 6343FTS646901268
    Subsystem 3 - Serial number: 6353ETS63JLLTVNH
    Subsystem 4 - Serial number: 6363ETS6S3FMTVNP
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    No fault code found.
    Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
    Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ
    Component: J0527 0025
    Revision: 00030000 Serial number: 3C5953507BN
    Coding: 0000501
    VCID: 74B120E9E2B90C7765F-8020
    Subsystem 1 - Part No: 3C8 959 537 Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAP H2ÿ 0021
    Coding: 00000226
    Shop #: WSC 00000
    Coding: 440F00
    1 Fault Found:
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 16
    Reset counter: 209
    Mileage: 330023 km
    Date: 2018.08.12
    Time: 13:01:57
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 209
    Mileage: 330023 km
    Time Indication: 0
    Date: 2013.01.02
    Time: 13:01:59
    1 Fault Found:
    01176 - Key
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 14
    Reset counter: 169
    Mileage: 265356 km
    Time Indication: 0
    Date: 2010.06.13
    Time: 18:01:19
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
    Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
    Component: J386 TUER-SG FT 1532
    Revision: 71009005 Serial number: 00000611488607
    Coding: 0000693
    VCID: 40D9BC39E681E0D7317-8014
    1 Fault Found:
    00932 - Electric Window Motor; Drivers Side (V147)
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 169
    Mileage: 0 km
    Time Indication: 0
    Revision: 00H15000
    5 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 219
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Voltage: 0.00 V
    PD
    RPM: 0 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Count: 0
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 50
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Voltage: 0.00 V
    PD
    Speed: 0.0 km/h
    Torque: 0.0 Nm
    Torque: 0.000 Nm
    Term 15 On
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 9
    Reset counter: 211
    Mileage: 329247 km
    Time Indication: 0
    Date: 2012.12.25
    Time: 17:10:15
    Freeze Frame:
    Voltage: 13.63 V
    DU
    Temperature: 58.0°C
    RPM: 781 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Count: 0
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 219
    Mileage: 330023 km
    Time Indication: 0
    Date: 2013.01.02
    Time: 13:02:01
    Freeze Frame:
    Voltage: 11.88 V
    DU
    Temperature: 13.0°C
    RPM: 1498 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Count: 0
    000 - - - MIL ON
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 330023 km
    Time Indication: 0
    Date: 2013.01.02
    Time: 00:00:34
    Freeze Frame:
    PD
    Temperature: 18.0°C
    Count: 2
    Count: 0
    SteerAng n.Init
    Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 042 0472
    Coding: 01910A0001860E763604941570085FCE107C01
    Subsystem 1 - Part No: 1K0 951 605 D
    Component: LIN BACKUP HORN H08 9001
    Subsystem 2 - Part No: 3C0 951 171 C
    Component: Neigungssensor 004 0611
    Subsystem 3 - Part No: 3C0 951 171 C
    Component: Innenraumueberw.004 0611
    2 Faults Found:
    00323 - Vehicle Inclination Sensor (G384)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 191
    Mileage: 328852 km
    Time Indication: 0
    Date: 2012.12.17
    Time: 21:34:53
    01038 - Central Locking Thermal Protection
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 4
    Fault Frequency: 9
    Reset counter: 209
    Mileage: 330023 km
    Time Indication: 0
    Date: 2013.01.02
    Time: 02:11:49
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
    Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
    Component: J387 TUER-SG BT 1532
    Revision: 71009005 Serial number: 00000255488609
    Coding: 0000692
    VCID: 41DFB93DED8BE9DF3E9-8014
    1 Fault Found:
    00933 - Electric Window Motor; Passenger Side (V148)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 169
    Mileage: 330023 km
    Time Indication: 0
    Date: 2013.01.02
    Time: 00:00:02
    Address 53: Parking Brake Labels: 5N0-907-801.clb
    Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
    Component: J540 EPB3 VW-10498 0003
    Revision: 008 Serial number: 00000000047365
    Coding: 0000057
    VCID: 280904996EF13897197-807C
    5 Faults Found:
    03200 - Switch for Electric Parking Brake (E538)
    Freeze Frame:
    Fault Priority: 1
    Reset counter: 209
    Mileage: 309447 km
    Time Indication: 0
    Date: 2012.03.11
    Time: 22:45:21
    Freeze Frame:
    Voltage: 13.50 V
    Count: 10
    Speed: 0.0 km/h
    Hex Value: 0x12F0
    Hex Value: 0x0001
    Hex Value: 0x1001
    02433 - Supply Voltage for Right Parking Brake Motor (V283)
    011 - Open Circuit - MIL ON
    Freeze Frame:
    Fault Status: 11101011
    Fault Priority: 2
    Fault Frequency: 127
    Reset counter: 169
    Mileage: 329757 km
    Time Indication: 0
    Date: 2012.12.29
    Time: 20:14:35
    Freeze Frame:
    Voltage: 13.10 V
    Count: 31
    Speed: 0.0 km/h
    Hex Value: 0x1171
    Hex Value: 0x0008
    Hex Value: 0x0801
    16366 - Control Module - Internal Malfunction; CPU 2
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 204
    Time Indication: 0
    Freeze Frame:
    Voltage: 11.70 V
    Count: 41
    Speed: 0.0 km/h
    Hex Value: 0x0871
    Hex Value: 0x0008
    Hex Value: 0x1001
    16352 - Control Module - Electrical Error
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 151
    Reset counter: 209
    Mileage: 315106 km
    Time Indication: 0
    Date: 2012.06.27
    Time: 15:50:60
    Freeze Frame:
    Voltage: 12.90 V
    Count: 42
    Speed: 0.0 km/h
    Hex Value: 0x12F0
    Hex Value: 0x0001
    Hex Value: 0x0101
    03288 - Lining/Pad Change Mode Active
    000 - - - MIL ON
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 169
    Time Indication: 0
    Freeze Frame:
    Voltage: 11.40 V
    Count: 44
    Hex Value: 0x0171
    Hex Value: 0x0082
    Hex Value: 0x1001
    Coding: 0500040004
    1 Fault Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 169
    Mileage: 330023 km
    Time Indication: 0
    Date: 2013.01.01
    Time: 19:23:10
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 3C8 959 703 B HW: 1K0 959 795 Q
    Component: J388 TUER-SG HL 0309
    Revision: 43004101 Serial number: 00000000444284
    Coding: 0000144
    VCID: 313FE9FD5D2B795FCE9-8064
    1 Fault Found:
    00934 - Electric Window Motor; Rear Left (V26)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 169
    Mileage: 330023 km
    Time Indication: 0
    Date: 2013.01.02
    Time: 00:00:02
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 3C8 959 704 B HW: 1K0 959 794 Q
    Component: J388 TUER-SG HR 0309
    Revision: 43004101 Serial number: 00000000442392
    Coding: 0000144
    VCID: 323DE6F1582D4247B73-8066
    1 Fault Found:
    00935 - Electric Window Motor; Rear Right (V27)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 169
    Mileage: 330023 km
    Time Indication: 0
    Date: 2013.01.02
    Time: 00:00:02
    End----(Elapsed Time: 01:42, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
  5. Re: Throttle body (ASV) & cooling fan problem
    1837 Post(s)
    Won’t these codes clear? What has happened to this car, has it been twated on the nose?
  6. Re: Throttle body (ASV) & cooling fan problem
    Oct 2017
    22 Post(s)
    light damage on front right side which caused body to scuff but no serious collision. the door errors, steering and abs errors are down to the car having the battery removed. the air flow error is due to me removing maf to test the starter motor. But as you can see in multiple modules there is engine control module error of there being no signal. this may be due to the engine not being turned on. Do you have any suggestions? I found the real figures of starter motor voltage drop, its 004.7 and 005.5v which doesn't sound too significant for the engine to fail. Can you tell me where the fuse is for ASV/cooling fan. perhaps ecu thinks due to that not working that asv is in closed position so is not starting? I called AA today, they have taken it to garage after testing battery, alternator and starter. But I doubt garage will figure it out. After testing battery, starter, alternator, fuses, relays where do you go from there? clutch position sensor could be faulty but that would throw a code.
  7. Re: Throttle body (ASV) & cooling fan problem
    1837 Post(s)
    Start at the top, why does it show an Air Mass Metr fault?
  8. Re: Throttle body (ASV) & cooling fan problem
    Oct 2017
    22 Post(s)
    Because I removed it while the battery was on so I could check the starter.
  9. Re: Throttle body (ASV) & cooling fan problem
    1837 Post(s)
    Can you do a full clear then drive it, then read and save again.
  10. Re: Throttle body (ASV) & cooling fan problem
    Oct 2017
    22 Post(s)
    I can't drive it, it won't start remember? I have cleared it before, then done a rescan. It doesn't show any engine faults. I have also tried both keys to see if the key is failing but nothing. I'm going to work for six days straight now so till then all I can do is search for suggestions. I will have to visit the garage with my vagcom and clear everything and do a rescan.
  1. Question Throttle body alignment problem
    By chefnikosdaniil in forum VCDS - General Questions
    Last Post: 18-07-2018, 10:08 PM
  2. Clean throttle body and perfom Throttle Body Alignment (TBA) - big job?
    By allanmb in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-01-2013, 09:50 PM
  3. A4 B5 throttle body reset problem with VAG
    By adrianwillis in forum VCDS - General Questions
    Last Post: 09-09-2011, 12:12 PM
  4. Another gearbox problem or throttle body?
    By a4_jim in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-08-2008, 09:51 AM
  5. Throttle body & breather problem
    By roy rovers in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-05-2008, 06:27 PM
