Thread: Throttle body (ASV) & cooling fan problem
Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. Re: Throttle body (ASV) & cooling fan problem
    #21
    Oct 2017
    Halifax, West Yorkshire
    22 Post(s)
    Yes, some say pedal, ecu or wiring between both. I will have a go at changing the pedal first and report back.
  2. Re: Throttle body (ASV) & cooling fan problem
    #22
    Oct 2017
    22 Post(s)
    Swapped gas pedal with a another pedal with each having same part number. I thought I solved it till today, put foot down km motorway and limp mode came back after car juddered. I don't know what causes the car to pull back, but I suspect it's the cause of limp mode too. I will check codes tomorrow, I can't understand what is causing it to go to limp mode and the pull back action.
    Rear right does have more brake dust then the rest of the wheels, can a caliper brake pads touch the brake disc when driving without braking? The caliper was changed, it may have not been set properly via vcds.
  3. Re: Throttle body (ASV) & cooling fan problem
    #23
    Oct 2017
    22 Post(s)
    Can confirm P1388 code is still there even though its been cleared several times. I guess its time to check wiring from pedal to ecu, and wiring of throttle body to ecu. Does anyone have wiring diagram? And how am i meant to know if wiring is faulty if the wires look fine? I know youre meant to use a multimeter but to do that but everything has to be disconnected from the harness, and then a resistance test.
  1. Question Throttle body alignment problem
    By chefnikosdaniil in forum VCDS - General Questions
    Last Post: 18-07-2018, 10:08 PM
  2. Clean throttle body and perfom Throttle Body Alignment (TBA) - big job?
    By allanmb in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-01-2013, 09:50 PM
  3. A4 B5 throttle body reset problem with VAG
    By adrianwillis in forum VCDS - General Questions
    Last Post: 09-09-2011, 12:12 PM
  4. Another gearbox problem or throttle body?
    By a4_jim in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-08-2008, 09:51 AM
  5. Throttle body & breather problem
    By roy rovers in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-05-2008, 06:27 PM
