Thread: Advice needed - A4 B8 DAB Retrofit and Amp Coding - Bose to standard question
  1. Advice needed - A4 B8 DAB Retrofit and Amp Coding - Bose to standard question
    Nov 2014
    I have retrofitted a used Audi 4G0035061J DAB radio tuner unit to a 2011 Audi A4 B8 with the MMI 3G+ system and had component protection removed by a dealer.
    However there is no sound although the DAB is displaying correctly, showing stations etc.
    The dealer suggests there is an amp fault and web research now shows that the 4G0035061E unit can be con configured for Bose or standard systems.
    I have the standard system, and guess the tuner unit it came out of was a Bose equipped car.
    Therefore, is there a way, via the MMI screen green menus or VCDS, to change the system from Bose to standard on the tuner unit?
    Grateful for your advice.
  2. Re: Advice needed - A4 B8 DAB Retrofit and Amp Coding - Bose to standard question
    Nov 2014
    I think I may have answered my own question - this looks to be the recommendation
    3G DAB Radio Coding
    https://www.audison.eu/audison/asset...system_15A.pdf
    Long coding, 56 radio:
    01 = AM/FM EUR (02 USA)
    01 = DAB (fixed value) (00 sirius USA)
    03 = Operating Mode
    01 = External Amp (02 if the amp is inside, e.g.: not B&O)
    00 = Sound Profile
    00 = No info
    00 = No info
    00 = No info
    01 = Chassis
    The setting for “external amp” needs to be 01.
  1. Please Help A4 B6 Cabriolet BOSE Retrofit - Help Needed
    By jamin128 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-05-2015, 11:01 PM
  2. BOSE coding
    By CharlesElliott in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 14-12-2014, 02:10 PM
  3. Back to standard alloys, advice needed.
    By dean1986 in forum Wheels and Tyres
    Last Post: 07-04-2014, 06:28 PM
  4. Bose vs Standard sound
    By chucky in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 30-03-2013, 10:27 PM
  5. Bose V's Standard
    By EV2UK in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-08-2011, 03:06 PM
