Thread: Is this a rip off body work quote?
  1. Is this a rip off body work quote?
    Jul 2018
    Harlow
    Ive been quoted 650 +vat to prepare and respray a little bit of surface rust on top of rear wheel arch , looks like and old scuff thats been left too long.
    They have quoted for removal of quarter panel and a door blend.
    Surely thats way too much, or am i just out of touch?
  2. Re: Is this a rip off body work quote?
    1840 Post(s)
    For a quality job that is about right and I would expect to have to blend the rear bumper as well, although they never matched from new. I can't see it being actual removal of the 3/4 panel as the panel is £300 on its own and it is a massive job. I can't make out from that picture if it is from the inside, it it is the damage needs to be cut out, a repair section fabricated, welded in, linished, leaded and painted and that is easily £650 if not more. If it is from behind, tapping it back and using filler won't last a year before it shows again.
    This is the sort of repair required if you get rot all around and to get the panel you may well end up buying a full rear 3/4 to cut off the lip as I don't know of a repair panel for that. This is an aftermarket arch repair panel, cut right down, welded and linished before lead.
  3. Re: Is this a rip off body work quote?
    Dec 2008
    dad used to do body work...seems pricy
  4. Re: Is this a rip off body work quote?
    Dec 2008
    although is that all you're getting fixed
  5. Re: Is this a rip off body work quote?
    Dec 2008
    if the work is exceptional standard it may be worth it.....
  6. Re: Is this a rip off body work quote?
    Dec 2008
    i just checked the pics there.....thats not bad for the amount od work needed
  7. Re: Is this a rip off body work quote?
    1840 Post(s)
    Quote Originally Posted by nuglol View Post
    In the last decade the costs of bodywork materials have rocketed plus regulation has gone nuts over emissions, I imagine your dad liked cellulose for some jobs, try buying that now.... all you can use is water base which is supper delicate and then lacquer which if you inhale it, it kills you. Also, now body guys are getting paid a going rate for what they do rather than being paid no better than a house painter, perfect paint is what people expect and it is not easy.
  1. new headlights don't work please help stuck at body shop
    By stickycreationz in forum Vehicle Security - Retrofit / aftermarket alarms & immobilisers
    Last Post: 26-11-2014, 12:11 PM
  2. Body work warranty
    By oldandbald in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-05-2014, 08:40 PM
  3. Body shop/work recommandation!!
    By DiazSprite in forum Body Work, Body Styling and Body Kits
    Last Post: 09-04-2013, 01:34 AM
  4. Please Help Vindis body shop - poor work! advice pls
    By Kevster140 in forum Golf MK5 - 2004 - 2009
    Last Post: 10-03-2010, 11:21 PM
  5. Paint/Body work warranty??
    By danski in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-05-2009, 07:49 PM
