Thread: Golf Mk5 no dash power starts but dies instantly
  1. Golf Mk5 no dash power starts but dies instantly
    Aug 2018
    Hi Everyone,
    this is is my first post. I have read everything I can on the above. The car cannot be scanned by vagcom etc as the dash will not power up.
    I got the the car Saturday. Scuttle was badly clogged blocked so cleaned it carefully. Used the car later in the day. Sat evening had the above problem. I have Tried:
    disconnecting the battery including overnight
    ECU connections look fine but ECU not removed.
    No signs of water under the dash or in the car
    charging the battery.
    Replaced relay 460
    checking all fuses and relays including enginebay 433 A1 A2 position
    removing battery and checking cleaning all earths I could find
    removed dash checking terminals
    nothing, a VW specialist came out today but as he could not scan advised will need to go into his garage next week.
    Can anyone think of anything else I can try?
    thanks
    Ted
  2. Re: Golf Mk5 no dash power starts but dies instantly
    1836 Post(s)
    It will cut out instantly if the dash is not powering up as the engine ECU will not receive its start authorisation from the immobilser which is in the instruments. Can the rest of the cars system be accessed such as CAN BUS and engine ECU? Which year and engine code?
  1. HELP!!!! 1.6 TDi, starts and dies out!
    By DMcCo in forum Golf MK6 - 2009 - 2013
    Last Post: 14-10-2017, 05:06 PM
  2. Question Audi TT Starts then Dies
    By connollyb in forum New Member Introductions
    Last Post: 22-07-2010, 06:54 PM
  3. help a4 estate 1.9 tdi 130 starts then dies
    By foegal-2008 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-11-2009, 10:30 AM
  4. Please Help 2.5 tdi starts, runs 1 second and dies
    By scotchydoodle in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-02-2009, 09:55 PM
  5. starts from cold & Dies - BUT
    By robmar0se in forum Leon
    Last Post: 12-04-2008, 06:02 PM
