Thread: Snapped starter cable
  1. Snapped starter cable
    May 2007
    Golf wouldn't start yesterday, and on removing the battery cover, the starter cable had snapped clean off within the battery terminal clamp in which its crimped. My local dealer tells me a new cable is a back order job from Germany which is a pain.
    Does anyone know what current rating the cable is likely to be? The top few inches have heat shrink on them and the cable that doesn't is O/D of 11mm - suggesting its around 200A.
    I've done a temp fix which I thought I'd share since it only took me a few minutes to do. It involved drilling out the battery clamp with an M8 drill, sticking a bolt through it, and then clamping the stripped back cable to it with a couple of jubilee clips.
  2. Re: Snapped starter cable
    Jul 2010
    Monmouth, Wales
    7 Post(s)
    One of my old workmates used to say "there's nothing so permanent as a temporary repair". I would just tape that up & forget it if it was my car.
  3. Re: Snapped starter cable
    1841 Post(s)
    Excellent bodge, love it
  4. Re: Snapped starter cable
    May 2007
    Why thank you Mr Crasher - nice to know my handywork is appreciated!
  5. Re: Snapped starter cable
    May 2007
    Just to close the loop on this, I decided to order the proper cable. Took two attempts by my local dealer to get it from Germany, but it's sorted now.
  6. Re: Snapped starter cable
    1841 Post(s)
    The dealer should not have struggled, even though there are 10 different cables for a later 2001 your car will be FI Suggestion linked and even without the VIN I would guess the cable you needed was 1J0 971 228 BC at £48.35 retail, based on my assumption it is a later 2001 and has a 1.6 16v engine such as a BCB.
  7. Re: Snapped starter cable
    May 2007
    It's a 1.6 8V auto (0-60 time "leisurely" but enough for Mrs Midge!). They were given the VIN, but the first to arrive was an AG when they should have ordered/shipped a BG. I knew there were a few different types but not sure how they can justify making 10 variants of a simple cable. Anyway, sorted now. Cheers.
  1. Attention Bonnet cable snapped
    By markoA4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-10-2013, 08:57 AM
  2. cabriolet snapped window cable
    By toptek in forum Golf MK4 - 1999 - 2004
    Last Post: 09-05-2012, 09:22 PM
  3. snapped electric window cable
    By andrew-spike in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 01-10-2011, 07:55 PM
  4. Bonnet release cable snapped
    By charbel89 in forum Touran - Sharan - Caravelle
    Last Post: 14-09-2008, 09:00 PM
  5. Elec Window Cable snapped
    By Timbo in forum Archive posts
    Last Post: 20-07-2007, 10:14 PM
