Thread: tdi sport avant 1.9 AVF timing belt parts
  1. tdi sport avant 1.9 AVF timing belt parts
    Jul 2018
    Harlow
    Can i please get advice as to whether its wise to use non VAG kits was thinking of purchasing a Dayco kit and First Line water pump?
    Also can i get confirmation as to whether its every 50,000 miles, 80,000 miles or every 5 yrs?.
    Thanks in advance
    Andrew
  2. Re: tdi sport avant 1.9 AVF timing belt parts
    May 2012
    Everywhere
    308 Post(s)
    Dayco is VAG OEM .
  3. Re: tdi sport avant 1.9 AVF timing belt parts
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    When I had 1.9 pd engines I seem to remember the interval being 40k or 4 years, that was on 2004 touran and 2005 passat, does it not say in the service book? I bought the passat with 1.9 engine with 70 odd k and over 6 years on the belt and pump. Belt looked fine but there was some play in the pump bearings so probably due a change by then! If you're thinking about it you won't sleep sound until its done. I used VAG kits and pumps from TPS, pump was surprisingly cheap once old pump was returned for deposit,and the belt kit was comparable to others such as Dayco etc. Some reckon you should change the tensioner stud as well if the belt has already been changed a few times.
  4. Re: tdi sport avant 1.9 AVF timing belt parts
    Jul 2018
    Harlow
    Cheers Rob it's definately getting done, believe it or not was first thing in my head when I woke this morning : )
  5. Re: tdi sport avant 1.9 AVF timing belt parts
    Jul 2018
    Harlow
    Quote Originally Posted by Gazwould View Post
    Dayco is VAG OEM .
    that's good news, thankyou
  1. Manufacturer of OEM parts for Timing Belt Change - 2.5 TDI BDH
    By noetus in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-03-2018, 12:20 PM
  2. Please Help Mk5 sport tdi 2.0 timing belt off
    By Amadhain in forum Golf MK5 - 2004 - 2009
    Last Post: 05-03-2016, 02:28 PM
  3. Question Parts for timing belt change
    By bagpipingandy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-11-2009, 06:06 PM
  4. Question 2006 2.0TDI SPORT Timing belt replacement
    By CNPrior in forum Jetta MK3 - 2005 - 2013
    Last Post: 16-07-2009, 10:51 PM
  5. passat 1.9 tdi sport timing belt ??
    By tennentsfan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-05-2008, 01:01 PM
