Thread: Audi A6 boost issue
Results 11 to 20 of 25
  1. Re: Audi A6 boost issue
    Jan 2019
    Dublin
    Quote Originally Posted by Renars View Post
    Well impressive mechanical skills there.
    Thank you for your reply was very helpful , I've the car booked in earliest is 3 weeks with main dealer , so thought I'd share the thread as seems that it's similar issue that wasn't resolved as of yet,. When the car glow plugs comes up the diagnostics reads several faults air bag abs tpsm but it's obvious that it's not all of them and one is triggering them all in the ecu ,. So far drive 50 miles today all good ,had the snap on diagnostics plugged in at work no issue as obviously as said it comes and goes , hopefully an easy fix as car runs smooth full of power and low milage ,. I'll let you know in 3 weeks when Audi have it in the workshop . Of noone has figured it out before...
  2. Re: Audi A6 boost issue
    Jan 2018
    Sussex
    55 Post(s)
    When glow plug light stays lit after startup it has nothing to do with airbags, abs...
    Proper VAG scan tool will pick up codes.
    To shed any light exact codes are needed .
    Its easy with cars now - warning lights appear only if codes are stored.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
  3. Re: Audi A6 boost issue
    Mar 2014
    Edinburgh
    235 Post(s)
    With a few unrelated errors like that have you checked the battery?
    A dying battery can wreak havoc on electronics. Even though there’s enough power to start the car it might not be enough to keep everything running properly.
    0 2 0
  4. Re: Audi A6 boost issue
    Jan 2019
    Dublin
    Ok so sat in my car on my break only put ignition on to listen to radio, the glow plugs yellow warning came on,. Decided to try and clear code wouldn't work, disconnected the battery came back 2 hours later reconnected it, didn't work glow plugs warning still present ,. I've left the car at work and company mechanic will get me the turbo pressure sensor as this is the main fault showing , if it works I'll be delighted as the Audi waiting list for the car to be done is weeks away, when the glow plugs warning comes on so does the tpms come on and the airbag and brakes and park brake so it seems to trigure alot of sensors even the left air vent sensor the roof antenna and the gearbox sensor , I'll keep you updated and if anyone else has had this issue please let me know . I'm trying to upload photos from my phone but having no luck,. New on here and I click images but not a button to say ok.
  5. Re: Audi A6 boost issue
    Jan 2018
    Sussex
    55 Post(s)
    With many unrelated errors you have to consider it might be old battery even if it cranks fine.
    Current cars:
  6. Re: Audi A6 boost issue
    Jan 2019
    Dublin
    Ok mechanic got a turbo boost pressure sensor also known as the dpf pressure sensor , has the 2 hose connected to it, he got it from his motor factors not the exact A6 190ps type but similar , didn't work car still in safety mode ,. So I'm going to Audi in the morning to buy the exact same sensor that's for my car , I spoke to a polish mate of mine and he called his mate who works for Audi as a mechanic and he said they had an Audi in with the same issue loads of faults coming up the turbo pressure sensor the main cause , they fitted a new sensor but didn't work and they realised after that the sensor has to be the exact same serial number etc , if the Audi is 190ps the 170ps or 140ps won't take to the car ,. They used the correct sensor and all perfect , I hope this is the case and mine will be ok tomorrow, if not this Audi mechanic will have a look after for me at his garage at his house.
  7. Re: Audi A6 boost issue
    #17
    Jan 2019
    Dublin
    IMG-20190105-WA0007.jpg.
    This is what parts gave me today ,. And correct sensor ? This is diagram for 2015 A6 2.0 arrow shows sensor cost me 67e with 12.5 % trade discount
  8. Re: Audi A6 boost issue
    #18
    Jan 2019
    Dublin
    Hi,. Just getting used to using this website, so appologies for replies late or after,. If the sensor does not work today I will buy a new battery the error code is P023700
  9. Re: Audi A6 boost issue
    #19
    Jan 2019
    Dublin
    P023700
  10. Re: Audi A6 boost issue
    #20
    Jan 2019
    Dublin
    Happy days issue sorted it was the turbo pressure sensor car is perfect now , I'll attach photos and thanks for all the advice and I hope this can solve anyone else with this issues problem , it caused all them faults to come up which now don't , I've attached diagram and the photos of new sensor fitted. Part number for the turbo charger sensor for Audi A6 c7 is : 04L 906 051 K.
    0 3 0
  1. Strange boost issue (base boost sometimes)
    By fivepointnine in forum Leon
    Last Post: 10-04-2017, 11:48 AM
  2. Help me please with my boost issue !?!
    By tomwhite1985 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 08-05-2016, 01:07 PM
  3. Important Audi A3 turbo boost issue??
    By Big Tim in forum Chat - Anything with wheels
    Last Post: 12-05-2015, 05:31 PM
  4. '99 2.5 TDi Boost issue.
    By jezzo in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-07-2014, 05:33 PM
  5. Brake servo issue and possible linked boost issue
    By slipperyox in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2012, 10:06 PM
