yesterday i was driving when my car audi q7 2008 suspension warnning light tuened on and front suspention went down.i never had any suspension warning light before. now front suspension is down and back is fine amber light is steady but green is blinking. my VDc are
01310 - Level Control System Control Module (J197)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 0
Mileage: 199248 km
Time Indication: 0
Date: 2018.07.27
Time: 20:08:37
Address 34: Level Control Labels: None
Part No SW: 4L0 910 553 C HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7660
Revision: --H03001 Serial number: 15.1528-0096.2
Coding: 0015510
Shop #: WSC 31414 790 00001
VCID: 2A5B68CE853E0312DE-807E
7 Faults Found:
01770 - Temperature Sensor for Level Control Pump/Compressor (G290)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 2
Reset counter: 0
Mileage: 199246 km
Time Indication: 0
Date: 2018.07.27
Time: 16:41:57
Freeze Frame:
Error Code: 30
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 24
Reset counter: 0
Mileage: 199246 km
Time Indication: 0
Date: 2018.07.27
Time: 16:42:01
Freeze Frame:
Error Code: 68
02250 - Function Deactivation; Valve Duty Cycle
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 0
Mileage: 199247 km
Time Indication: 0
Date: 2018.07.27
Time: 19:53:47
Freeze Frame:
Error Code: 46
01583 - Leak in System Detected
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 199248 km
Time Indication: 0
Date: 2018.07.27
Time: 20:14:27
Freeze Frame:
Error Code: 70
01575 - Control Switched Off
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 216
Mileage: 199248 km
Time Indication: 0
Date: 2018.07.27
Time: 20:12:44
Freeze Frame:
Error Code: 69
01316 - ABS Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 216
Mileage: 197800 km
Time Indication: 0
Date: 2007.05.16
Time: 14:31:14
Freeze Frame:
Error Code: 98
01399 - Relay for Level-Control Compressor (J403)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 197800 km
Time Indication: 0
Date: 2007.05.16
Time: 13:13:39
Freeze Frame:
Error Code: 49
after clearing the dtcs code
Coding: 0015510
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 216
Mileage: 197800 km
Time Indication: 0
Date: 2007.05.16
Time: 14:44:01
Freeze Frame:
Error Code: 69
please help me
thanks
barlas
