Thread: 09 TDI (140) non-start! ECU?
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: 09 TDI (140) non-start! ECU?
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    On my Golf that 100 from your picture which is A1 on diagrams.
    Can be various numbers.
    Terminal 30 Input Relay (J317) 109 458/100 207 219 643 644
    On 2007 Golf GT 2.0 TDI-PD.
    Terminal 30 Input Relay (J317) 100 458
    Relay code number 100 is replaced by relay code number 370 depending on production.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  2. Re: 09 TDI (140) non-start! ECU?
    1840 Post(s)
    That is an ebox low, I have just serviced an identical car, this is it's box which is also eBox low even though it is a specked up Highline
    I was going to try and explain the ambiguity in ELSA but lost the will to type... so I looked to ETKA for inspiration and that says the number is 644! Plot, lost.... The trouble is I have too much to do today to unravel it all. Using the VIN of the car I have here, (Golf 6, 2009 CBAB) ETKA FI Suggestion states that position 1 should have a 644 relay part number 4H0 951 253. The realy in this one is part number 7M0 951 253 A and it is AE brand from 04/09 which means it is the factory fitted relay made by Auto Europa originaly designated for a Sharan and AE made the Sharan 7M in Portugal, this is Italian! Confused you will be! So the relay it has is 7M0 951 253 A and it should have (according to FI ETKA) 4H0 951 253 but if you put the &M number into ETKA part number look up, this changed to 4H0 951 253 on 01/04/2010 and indeed has 644 on top.
    I'm going home, it's 32 degrees in my hovel...
  1. Replies: 3
    Last Post: 15-08-2016, 09:21 AM
  2. Replies: 3
  3. Solved BLB engine too hard to start... but after starting the next start is normal..
    By matrixpt in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-05-2014, 11:51 AM
  4. Please Help On start up intermittent glow plug flashing non start engine fault garage flashes up
    By dazcheff in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-09-2012, 08:39 PM
  5. Won't start: faulty start valve?
    By Shaka1976 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-07-2010, 04:22 PM
