Thread: ABS Speed sensor Hub wheel bearing
Results 1 to 10 of 12
  1. ABS Speed sensor Hub wheel bearing
    Aug 2010
    west midlands
    Hi Guyz
    got a 2011 Passat 2.0 tdi 170hp. A few days ago Parking EPp & ABS light came on in the morning, in the afternoon they went off again, on my way that night came on again. Saturday I used a Carista OBD reader fault code 03841 & 00290 left wheel speed sensor. When I drove off the lights when out, I cleared the codes with the OBD reader. Sunday I took it for a 200 mile motorway drive, no light nothing car drives normal, no noise from the hub anything? no codes nothing
    Now I don't think it can be a faulty sensor as once that goes the light would constantly stay on. It could either be the hub/wheel bearing on way out or brakes wearing out? Has anyone had any similar issues? What to do? Any advise welcomed. Car has about 45k miles on it.
    thankz
  2. Re: ABS Speed sensor Hub wheel bearing
    Sep 2015
    North West
    I've got similar lights on at moment, 5 I total.
    I'm convinced it's the sensor, they don't always fail instantly and mine became intermittent over two days then failed completely.
    I've used VCDS and traced it to rear left wheel speed sensor, implausible signal.
    Ordered one, 16 quid, and will be fitting it this week.
  3. Re: ABS Speed sensor Hub wheel bearing
    Aug 2010
    west midlands
    16 quid? They about 75 quid frim dealers? Are you using third party part? Let us know where from if genuine
  4. Re: ABS Speed sensor Hub wheel bearing
    Sep 2015
    North West
    I bought it on eBay mate, it's not genuine / OEM but that hardly matters. Europart type stuff that most non- dealerships would fit, think it's Apec branded.
  5. Re: ABS Speed sensor Hub wheel bearing
    Aug 2010
    west midlands
    thanks light back on today but the sensor error fault didn't show 00290, just ABS 03841 & 01316. I'll change the rear left hub & sensor & see how it goes
  6. Re: ABS Speed sensor Hub wheel bearing
    18 Post(s)
    460 Post(s)
    The magnetic ring on the back of the bearings rusts and breaks up.
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
  7. Re: ABS Speed sensor Hub wheel bearing
    Sep 2015
    North West
    Update on this. I had some faff getting the correct sensor...
    EBay one was wrong sensor, local factors then proceeded to order the wrong side! They eventually sorted a Bosch sensor for 35 quid. Fitted and problem solved, all lights out, ABS and stop start functioning again.
    Result.
  8. Re: ABS Speed sensor Hub wheel bearing
    18 Post(s)
    460 Post(s)
    Did the end of the old sensor show any signs of rubbing?
  9. Re: ABS Speed sensor Hub wheel bearing
    Sep 2015
    North West
    No, nothing. The pickup wasn't clean and perfect, it looked worn, but no scratches or obvious abrasion.
  10. Re: ABS Speed sensor Hub wheel bearing
    18 Post(s)
    460 Post(s)
    Worn? It is a close proximity non contact device
  1. Rear wheel speed sensor issues
    By ianlovatt in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-03-2019, 08:46 PM
  2. Wheel speed sensor replacement
    By BluestarT25 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-09-2013, 10:28 AM
  3. Fault 00287 - ABS Wheel Speed Sensor: Rear Right
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 18-09-2013, 08:13 AM
  4. TT Wheel speed sensor
    By nickgtn in forum VCDS - General Questions
    Last Post: 09-09-2008, 01:12 PM
  5. ABS - wheel speed sensor (s3)
    By Jon_Halibut in forum Audi A3 - Archive Topics
    Last Post: 15-06-2007, 03:08 PM
