Thread: Oil pressure switch location
  1. Oil pressure switch location
    Jul 2018
    Torquay
    any one know where it is, cannot find it, manual states on the back of engine on right side corner below engine hanger bracket, other states it on the oil filter house which i can not see it on there eithergolf-mk6-9996.jpg
  2. Re: Oil pressure switch location
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    You don't say which engine as you do in your other post.
    Car info:
    Golf estate 2009 (58)
    2.0 140bhp diesel engine
    Engine code (CBD)
    Its easier to add your car spec in your signature as regular users do. Where is that picture taken from ElsaWin?
    Manufacturer: VW, Date(s) Used: 07/2009-07/2010, Model: Golf/Variant/4Motion, Engine Code: CBDB, 103Kw, 140PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Common Rail (TDI-CR), 16v Timing belt Timing gears
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  3. Re: Oil pressure switch location
    Jul 2018
    Torquay
    Hi sorry about that, but manage to sort it, it was on the filter housing but had decayed away and the wiring was under coolant pipes
  1. Oil pressure switch location 1.6tdi
    By Amsel in forum Golf MK6 - 2009 - 2013
    Last Post: 19-08-2015, 04:36 PM
  2. Please Help T4 oil pressure switch location
    By TomP in forum The Commercial Range
    Last Post: 10-01-2011, 08:08 PM
  3. oil pressure switch location
    By neils4381 in forum Polo - Derby - Lupo - Fox
    Last Post: 23-11-2010, 08:44 PM
  4. Please Help air conditioning pressure switch location
    By pencastle in forum Touran - Sharan - Caravelle
    Last Post: 16-07-2010, 09:23 PM
  5. Golf V5 oil pressure switch location???
    By neil b in forum Golf MK4 - 1999 - 2004
    Last Post: 16-03-2007, 05:40 PM
