Thread: Pulsing / jerking when decelerating 2001 2.5tdi quattro
Results 11 to 20 of 31
  1. Re: Pulsing / jerking when decelerating 2001 2.5tdi quattro
    #11
    Aug 2008
    Isle of Skye
    Quote Originally Posted by skyegtb View Post
    Hi. I didn't find the time to investigate this until now, but to be clear, does the driveshaft need to be removed to check for the 'looseness / play' in the bearing. I did note some oil leakage in that exact area, so think you are likely to be correct.
    Also, what is involved in replacing the bearing and seal that is shown above?
  2. Re: Pulsing / jerking when decelerating 2001 2.5tdi quattro
    #12
    Aug 2008
    Isle of Skye
    JHM Audi B5-B6-C5 01E 6-Speed Manual Transmission Rebuild DIY/Tutorial/Instructions - FREE - YouTube
    Looking at this video on youtube the mechanic here says he has never seen a diff bearing fail on an 01E! He does explain how to gain access to inspect it though. Look from 1h24m30s. Is this the location for the bearing you mentioned above?
  3. Re: Pulsing / jerking when decelerating 2001 2.5tdi quattro
    #13
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    Very easy to replace. Just remove the axis and the Output flange
  4. Re: Pulsing / jerking when decelerating 2001 2.5tdi quattro
    #14
    Aug 2008
    Isle of Skye
    Quote Originally Posted by amiram View Post
    Care to share a 'How to?'
  5. Re: Pulsing / jerking when decelerating 2001 2.5tdi quattro
    #15
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    1 hour Work with the appropriate tools
  6. Re: Pulsing / jerking when decelerating 2001 2.5tdi quattro
    #16
    Aug 2008
    Isle of Skye
    OK, so is the job as follows? Remove drive shaft, unbolt and remove flange, remove seal with prybar or similar, remove diff cover then slide hammer to pull out the bearing, then press the new one in? What are the 'appropriate tools'? I have a slide hammer but no attachment for it like in your picture, also I do not have a press tool like the pictured one. What does the text say in your picture? Do you have VAG tool numbers for the necessary puller / press items?
  7. Re: Pulsing / jerking when decelerating 2001 2.5tdi quattro
    #17
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    Do not need to remove the diff cover!
  8. Re: Pulsing / jerking when decelerating 2001 2.5tdi quattro
    #18
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    I built the inserting tool on my own with a home lathe
  9. Re: Pulsing / jerking when decelerating 2001 2.5tdi quattro
    #19
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    audi allroad A6 tiptronic front end vibration fix 5HP19FLA - YouTube Try this
    At the end of the work, do not forget to check the differential fluid level. (G 052145S2 )
  10. Re: Pulsing / jerking when decelerating 2001 2.5tdi quattro
    #20
    Aug 2008
    Isle of Skye
    Thanks, looks like I am all set to do the job,I just need to get a bearing puller attachment for my slidehammer first. As an update, without removing the driveshafts I note that on my car there is a fair amount of play on the drivers (right) side flange bearing, but also some (not as much) on the passenger (left) side. Looking at your video above, it appears the left side is much more complicated. Did you change the bearing on that side too?
  1. help please setting my timing on a 2001 a4 b6 2.5tdi quattro
    By white.akita in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 20-02-2012, 06:05 PM
  2. Anything specific to get checked when taking my 2001 A6 2.5tdi quattro for a service?
    By Donstalker in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-07-2011, 09:26 AM
  3. how to change disc and pads 2001 a6 2.5tdi quattro
    By ibby0101 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-04-2010, 12:09 AM
  4. Please Help 2001 passat tdi 100 jerking under load.
    By duanvogel in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2009, 09:25 AM
  5. Audi 2.5tdi Quattro Avant 2001 Auto
    By Bobkat in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-06-2008, 06:51 PM
