Thread: Volkswagen Golf 1.6 TDI Overheating issue
Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 63
  1. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #31
    1837 Post(s)
    I can’t see how the heater matrix could influence this problem.
  2. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #32
    Aug 2020
    Ticino
    I'm sure the pump works well, the old pump worked fine too, when I disassembled it I tried it, but once disassembled I changed everything, even the timing belt
  3. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #33
    Aug 2020
    Ticino
    Hello people,
    Problem found 😁😁😁, just as I thought. Today I bypassed the interior heating radiator, that is, I unplugged the 2 tubes from that radiator and fitted them together. I tried the car for about 30 minutes and the temperature always stuck to 90. The fan never started. I still want to try the car more with more time, but with 99% certainty the problem is the heating radiator in the cabin.
    Bypass photo: P-20200824-184652-v-HDR-On — ImgBB
  4. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #34
    1837 Post(s)
    That is very interesting, the heater matrix works on a full bypass flow method and total blockage should not compromise the cooling system.
  5. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #35
    Sep 2020
    Gorleston On Sea
    Quote Originally Posted by Pintofl View Post
    Hello people,
    Have you any update? Have exactly the same issue and been to 3 different mechanics and now actually at the vw main dealers and even they are struggling to find anything wrong on initial looks. They want to replace the radiator!
  6. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #36
    Aug 2020
    Ticino
    Quote Originally Posted by NorfolkGolf View Post
    I've been driving the car for three weeks with the passenger compartment heater radiator bypassed. so the machine does not overheat, it works perfectly. Saturday I replace it with a new one ordered online. you can try to bypass it like i did. just disconnect the two pipes that enter the passenger compartment and connect them together.
    which is your car? do you know the engine code?
  7. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #37
    1837 Post(s)
    That is very interesting. I can see how a Golf 7 would be affected like this but not a Golf 6.
  8. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #38
    Aug 2020
    Ticino
    this problem appears on CAYC engines, including golf 6 equipped with this engine.
  9. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #39
    1837 Post(s)
    I see CAYC’s every day, day in day out and I have not had that issue.
  10. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #40
    Aug 2020
    Ticino
    I don't mean that it happens to all CAYC engines, I know it's rare but I know of some cases. also there are 2 types of thermostats in CAYC engines, I think it only happens in early CAYCs. I finally had some time to replace the small radiator in the cockpit. the car works perfectly.
    I made a little video showing you how the radiator was clogged: https://youtu.be/oPLHMbG3MSY
    Photo:
    IMG_20200925_180138
    IMG_20200925_180133
    IMG_20200925_180127
  1. Please Help TDI Overheating Issue
    By churchwalk in forum Golf MK5 - 2004 - 2009
    Last Post: 19-08-2016, 01:41 PM
  2. Audi A4 2002 1.9TDI Overheating issue, Please help
    By PaulCsordas in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-02-2016, 01:38 PM
  3. Please Help Please help, Golf 130 tdi with strange overheating issue
    By Uselessgolf in forum Golf MK4 - 1999 - 2004
    Last Post: 15-10-2012, 11:16 AM
  4. Mk2 golf overheating
    By buzmuzguz in forum Golf MK2 - 1984 - 1992
    Last Post: 25-04-2011, 06:44 PM
  5. VR6 overheating issue
    By grayh in forum Golf MK3 - 1993 - 1999
    Last Post: 23-11-2008, 01:54 PM
