Thread: Volkswagen Golf 1.6 TDI Overheating issue
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 63
  1. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #21
    May 2020
    Shropshire
    Surely if the supplementary water pump had failed the main mechanical waterpump would be enough to keep the car from overheating. Would low battery output be enough to throw off the supplementary pump hence why higher revs it sometimes helps it, with the alternator charging faster?
  2. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #22
    Aug 2020
    France
    I have the same problem, I have golf 6 1,6 tdi 2010, my car overheat at idle to around 110 -120Celsius and when I’m on the highway it keeps between 95-105 Celsius
    I changed water pump, thermostat valve but nothing changed the macha it’s have no idea what it can be. Did you manage to resolve yours ?
  3. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #23
    1837 Post(s)
    When the car is overheating at idle (that's a particularly odd occurance), do the cooling fans come on?
  4. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #24
    Aug 2020
    France
    Yes the cooling fan is on most of the time but what I discovered last night is that the radiator is cold all the time it doesn’t heat up even when my car is overheating
  5. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #25
    Aug 2020
    France
    The mechanics are very confused each one ask me to change a different thing ... I would really appreciate if anyone could help me here
  6. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #26
    1837 Post(s)
    Have you checked the supplementary electric water pump is running?
  7. Exclamation Re: Volkswagen Golf 1.6 TDI Overheating issue
    #27
    Aug 2020
    Ticino
    I have exactly the same problem on my Seat Altea 1.6TDI 105 CAYC year 2010 .Engine overheats after 15/20 minutes of driving and the fan is always on.
    I'm a mechanic, I have already replaced the thermostat valve, the main water pump, the 2 temperature sensors, the coolant several times, opened and checked the secondary (electric) pump works perfectly. I don't think it is the head or the gasket, I have no oil marks in the water or water in the oil, I have no water consumption.
    Nobody knows anything ???
    I'm going crazy.
    sorry my english
  8. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #28
    1837 Post(s)
    The cooling fan is always on? Do you see the overheat on the gauge? Have you cross check the value in measuring blocks?
  9. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #29
    Aug 2020
    Ticino
    After the engine warms up, the fan turns on and remains on practically all the time. Yes, I see the temperature indicator go up. I also looked at the temperatures with the diagnostic device, the sensors work correctly, I replaced them anyway. I think it's something partially blocked. On the highway with the temperature at 110 degrees if I go up to constant 4000rpm in third at about 120kmh the temperature drops below 90 degrees. I read in a Spanish forum a similar case that was the interior radiator clogged, I will try to bypass it ...
  10. Re: Volkswagen Golf 1.6 TDI Overheating issue
    #30
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    I know you have changed the main water pump, but it sounds like the impellor is loose on the pump shaft.
    If you disconnect the small hose at the top of the coolant pressure vessel there should be a flow when the engine is running.
  1. Please Help TDI Overheating Issue
    By churchwalk in forum Golf MK5 - 2004 - 2009
    Last Post: 19-08-2016, 01:41 PM
  2. Audi A4 2002 1.9TDI Overheating issue, Please help
    By PaulCsordas in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-02-2016, 01:38 PM
  3. Please Help Please help, Golf 130 tdi with strange overheating issue
    By Uselessgolf in forum Golf MK4 - 1999 - 2004
    Last Post: 15-10-2012, 11:16 AM
  4. Mk2 golf overheating
    By buzmuzguz in forum Golf MK2 - 1984 - 1992
    Last Post: 25-04-2011, 06:44 PM
  5. VR6 overheating issue
    By grayh in forum Golf MK3 - 1993 - 1999
    Last Post: 23-11-2008, 01:54 PM
