Thread: Water pump leak
  1. Water pump leak
    Oct 2017
    Seaham uk
    I have a 1.8 2011 b8 engine CDHA
    has anyone had problems with the water pump leaking and what needs to be changed.
    Do I change the whole unit with thermostat or just the pump I’ve been looking around but I can only find the pump on it’s own
    I’m looking for advice and cost for replacement.
    Thanks.
  2. Re: Water pump leak
    May 2007
    knee deep in clunge
    14 Post(s)
    Its most likely the coolant module the water pump rarely leaks, however, I suggest you replace the full unit and check the electrical connector due to coolant leaking down the wiring loom.
    You will also need the little pipe that sits in the block which can be a most irritating bugger to refit, in addition, you will require vcds or similar to basic the module and the throttle body due to removing and vent the cooling system.
  3. Re: Water pump leak
    Oct 2017
    Seaham uk
    Thanks for the info I just need to find a place that stocks them so I can pick it up Monday
  1. q7 water pump leak ?
    By gcq7 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 16-04-2017, 11:12 PM
  2. Electric Water pump leak
    By roflynn in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-08-2011, 03:07 PM
  3. water pump leak
    By hoppouk in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 19-05-2009, 07:49 PM
  4. Please Help Coolant Leak From Coolant\Water pump Housing
    By Chappio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 03:30 PM
  5. MK2 Water pump leak.
    By Tommcdadeuk in forum Golf MK2 - 1984 - 1992
    Last Post: 14-04-2008, 11:40 AM
