Thread: 58 plate Passat clutch position sensor implausible signal problem
  1. 58 plate Passat clutch position sensor implausible signal problem
    Jul 2018
    Glasgow
    Hi all,
    I have been trying to get this sorted for a while now, but can't seem to get anywhere with it.
    The problem is bringing up a epb fault on the dash.
    Has anyone had a similar problem? Any help will be greatly appreciated.
    Cheers ,Tam
  2. Re: 58 plate Passat clutch position sensor implausible signal problem
    Oct 2017
    Halifax, West Yorkshire
    22 Post(s)
    Is it a clutch position sensor or epb fault?
  3. Re: 58 plate Passat clutch position sensor implausible signal problem
    Jul 2018
    Glasgow
    Implausable signal from clutch position sensor. Checked the values in vagcom and there is no change when clutch is pressed. This also happened with the new Master cylinder I fitted. Was wondering if anyone has proper wiring diagrams so I can test each wire in the multi plug e.g voltage, resistance etc.
  4. Re: 58 plate Passat clutch position sensor implausible signal problem
    Feb 2014
    Swansea, uk
    Having the same problem with mine. How did you solve it???
  1. 02000 - Switch Position, 008 - Implausible Signal
    By netmonky in forum VCDS - General Questions
    Last Post: 27-08-2018, 02:34 PM
  2. Replies: 0
    Last Post: 26-04-2018, 11:45 AM
  3. Mass Air Flow Sensor: Implausible Signal Polo TDI
    By Dsldude in forum Polo - Derby - Lupo - Fox
    Last Post: 06-04-2017, 12:47 PM
  4. Audi A4 2.0 TDI BPW Cab - G28 Engine Speed Sensor Implausible Signal
    By brasiliangringo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-11-2015, 11:19 PM
  5. Clutch pedal switch -F36, Implausible signal
    By AntJ in forum VCDS - General Questions
    Last Post: 07-04-2008, 09:58 AM
