Thread: Possible Replacement Battery
  1. Possible Replacement Battery
    Aug 2015
    West Mids
    7 Post(s)
    After 2 weeks not using the car it didn't start up so called recovery to jump start it on the drive (their battery pack didn't do the job, so they had to connect their van directly to the battery in the boot) - in the end it started up.
    The technician did some diagnostics and advised the battery needs replacing - car is a 62 plate and don't think its been replaced before or is this sales patter from the technician?
    Currently connected it up to my c-tek on trickle charge
    Question is do we think this will regenerate the battery enough along with some continued use and need not replace? - on a side note I may leave it on trickle charge as I am using another car more regularly.
    The cost for a new battery from audi totals £486! with labour and programing, if I do need a replacement can anyone suggest a more reasonable fitter?
    as a consequence the spoiler is stuck in the up position with the error warning on the instrument cluster
    Thanks in advance!
    Audi A7 (2012), Black Edition 245 PS Tiptronic, Phantom Black
  2. Re: Possible Replacement Battery
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    I wouldnt pay anyone that to change a battery! Thats crazy! Get the battery power rating and get a motorfactors to supply the same type. There will be the battery manufacturers code on a sticker (not a part number!) and if you get a like for like number I cant see a problem needing coding. The code is generally only maybe 5-6 characters long, and is usually along with the name...eg: Varta ######
    Alan.
    VW T6 150 DSG Camper £££
  1. Battery replacement
    By Clownfist in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 27-11-2017, 06:42 PM
  2. Replacement battery
    By beefio in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 13-02-2017, 10:05 PM
  3. Battery replacement
    By Dohnut in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 10-01-2015, 05:45 PM
  4. Replacement Battery
    By billcoleman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-02-2011, 12:03 PM
  5. Key Fob Battery Replacement
    By Grimmer in forum Archive posts
    Last Post: 02-11-2006, 11:17 AM
