Thread: Turbo problem P0234. how do I remove the turbo
  1. Turbo problem P0234. how do I remove the turbo
    Jun 2014
    newport, s wales
    my sons car BKD 140 engine has been giving error code P0234 Turbo Overboost for a while
    reset with a scanner and it is ok for a few days. Or sometimes fails 2-3 times a day
    He has asked me to investigate any avenues suggested while he is on holiday (lucky me)
    even to the extent of changing the turbo
    can anyone guide me through the removal procedure please?
    I don't have access to a lift and will be working on the drive from above and below on my back. Is it doable?
    any other pointers to check before the decision to swap is taken would be welcomed
    thanks
  2. Re: Turbo problem P0234. how do I remove the turbo
    Jan 2009
    Birmingham
    18 Post(s)
    Removing and installing turbocharger
    Special tools and workshop equipment required
    t Spring type clip pliers -VAS 5024 A-
    Removing
    Caution
    If the turbocharger has suffered mechanical damage (e.g. damaged compressor wheel), it is not sufficient merely to fit a new turbocharger. The following work must be performed in order to avoid further damage:
    t Check air cleaner housing, air filter element and air intake hoses for dirt and foreign particles.
    t Check the entire charge air system (including the charge air cooler) for foreign matter.
    t If foreign matter is found in the charge air system, clean all relevant ducts and hoses and renew charge air cooler if necessary.
    Observe rules for cleanliness when working on turbocharger → Chapter
    Engine cover panel (version 1):
    Pull dipstick -1- out of guide tube.
    Lift engine cover panel at sides -arrows 2- and pull off towards front -arrow 3-.
    Re-insert dipstick in guide tube.
    Engine cover panel (version 2):
    Lift off engine cover panel (outside -1- and inside -2-) by pulling up evenly.
    All vehicles (continued):
    Pull cover off air duct (release clips on sides) -arrows-.
    Unclip air duct at the bottom by releasing clips -arrows-.
    Detach air duct (bottom) together with air hose.
    Unplug electrical connector -1- at air mass meter -G70-.
    Detach vent hose -3- and air hose -2-.
    Unscrew bolt -4- and remove air cleaner housing.
    Unplug electrical connector -1- at oil pressure switch -F1-.
    Remove oil pressure switch -2-.
    Detach oil supply pipe at oil filter bracket -3- and at coolant pipe -4-.
    Disconnect hose going to vacuum unit for charge pressure control at separating point -arrow-.
    Note
    Shown from rear with engine removed for illustration purposes.
    Remove bolts -1- and -3-.
    Move vacuum hoses at rear intake pipe clear to one side.
    Disconnect hose -2- for crankcase breather system at air pipe.
    Release spring clip -4- with spring clip pliers -VAS 5024 A- and detach air pipe at connection for turbocharger.
    Note
    Remove centre noise insulation -fasteners 1 ... 3-.
    Remove noise insulation (right-side) -fasteners 1 ... 3-.
    Remove bolts -1- and -2-.
    Remove air pipe (right-side) by lifting retaining clips -arrows- slightly.
    Detach air intake hose from turbocharger by lifting retaining clip -arrow- slightly.
    Remove front exhaust pipe → Chapter.
    Remove bolts -1- and -2- and detach support for turbocharger.
    Remove oil return pipe -3- at cylinder block.
    Unscrew oil supply pipe at turbocharger and exhaust manifold -arrows-.
    Move oil supply pipe to the side.
    Remove connecting pipe for exhaust gas recirculation -arrows-.
    Remove heat shield from exhaust manifold -arrows-.
    Unscrew nuts -arrows-.
    Take out exhaust manifold/turbocharger between subframe and body.
    Installing
    Installation is carried out in the reverse order; note the following:
    Note
    t Renew seals, gaskets and self-locking nuts.
    t Fill turbocharger with engine oil at connection for oil supply pipe.
    t Hose connections and hoses for charge air system must be free of oil and grease before assembly.
    t Secure all hose connections with the correct type of hose clips (same as original equipment)→ Electronic parts catalogue.
    Install exhaust system and align it free of stress → Chapter.
    Adhere to the instructions for installing air pipes and hoses with plug-in connectors → Chapter.
    Install air pipes → Chapter.
    Check oil level → Chapter.
    Note
    After installing turbocharger, allow engine to idle for approx. 1 minute and do not rev up immediately to ensure turbocharger is supplied with oil.
    Tightening torques
    Component Nm
    Exhaust manifold/turbocharger to cylinder head 25 1)
    Heat shield to exhaust manifold/turbocharger 25
    EGR connecting pipe to: Change-over flap 20
    Exhaust manifold 25
    Oil supply pipe to turbocharger 22
    Bracket for oil supply pipe to exhaust manifold 25
    Bracket for turbocharger to: Cylinder block 40
    Turbocharger 20
    Oil return pipe to cylinder block 30
    Oil supply pipe to oil filter bracket 22
    Oil pressure switch to oil filter bracket 20
    l 1) Renew nuts.
    Power unit > 4-cylinder TDI unit injector engine (2.0 ltr. 4-valve), mechanics > Exhaust turbocharger, G-charger > Turbocharger and charge air cooling - vehicles with engine codes AZV, BKD > Removing and installing turbocharger
    [PREV PAGE] [NEXT PAGE]
    found this if it helps
  3. Re: Turbo problem P0234. how do I remove the turbo
    Jun 2014
    newport, s wales
    Hi and thanks for info
    I will print it off today for a reference doc
    now im just wondering if my arms are long enough to reach the manifold from underneath LOL
    are these manual docs freely available online?
    cheers
  4. Re: Turbo problem P0234. how do I remove the turbo
    Jan 2009
    Birmingham
    18 Post(s)
    pm sent
  5. Re: Turbo problem P0234. how do I remove the turbo
    Jun 2014
    newport, s wales
    I will read it when I get to my pc tonight
    cheers
  6. Re: Turbo problem P0234. how do I remove the turbo
    18 Post(s)
    460 Post(s)
    The main thing is you have to take it out to from below which means removing the right hand drive shaft. For a skilled tech with a lift and air tools who has done a few before you are taliking four hours off and five back on IF all the parts are correct. Remember EVERY single nut/bolt removed MUST be replaced... On your back on the drive, evil....
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
  1. Turbo oil feed line attached to back of engine, how to remove it?
    By mikeote in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-04-2017, 06:59 PM
  2. How to remove / replace 2.0 TDI GOLF TURBO GUIDE?
    By chris1391 in forum Golf MK5 - 2004 - 2009
    Last Post: 06-04-2013, 09:39 PM
  3. How To Remove/Replace turbo on 2007 2L diesel A4
    By roadkill443 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 15-11-2012, 07:30 PM
  4. Please Help need to remove turbo to clean vanes
    By churp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-02-2009, 02:06 PM
  5. P0234-turbo Overboast
    By jp4500 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-04-2008, 06:18 PM
