Thread: A6 Avant wobbling
Results 11 to 20 of 35
  1. Re: A6 Avant wobbling
    Mar 2018
    Wakefield
    10 Post(s)
    UPDATE :
    Had two new tyres put on the front and it’s still doing it.
    I’m more inclined to call it a shudder now and it’s apparent from 60mph right through to 120.
    Braking doesn’t affect it, neither does knocking it into neutral, it still stays. It actually makes the passenger seat shake.
    Has anybody got any suggestions??
    Could it be engine related? Crank bearing or flywheel or something?
    I don’t get it
    What about a four wheel alignment? Would that eradicate anything, although it doesn’t pull at all, she drives straight as an arrow
  2. Re: A6 Avant wobbling
    Feb 2016
    London
    13 Post(s)
    Difficult to speculate as to it's cause after you have tackled the usual suspects but I'd certainly not be driving at 120mph with such an issue.....
    I suggest you get it to a garage that can test the drivetrain without the wheels to rule these out and/or go to a garage equipped with a Hunter 'roadforce' balancing system which can identify not just blance issues but any wheel and tyre irregularities like out of roundness. A bent wheel or out of round tyre can balance perfectly but won't run smooth. If you have hit something with enough force to bend a wheel I'd also be worried about driveshaft damage and any other damage to suspension components. Even a worn / damaged shock absorber or loose strut mount can cause these issues.
    2011 A6 Allroad 3.0TDI
  3. Re: A6 Avant wobbling
    Mar 2018
    Wakefield
    10 Post(s)
    Thank you for that A6ALLROAD, appreciate your points.
    I don’t drive at 120 though mate, I juyst floored it on an empty road to see what it did, if it disappeared or eased off etc.
    I’ll get searching for somewhere with this machine
  4. Re: A6 Avant wobbling
    Jul 2013
    76 Post(s)
    have you swapped the wheels front back?
    If the wobble goes then and you feel the vibration in the seat then its one of the wheels.
    Dan
    2009/2010 2.0 TDIe SE
  5. Re: A6 Avant wobbling
    Mar 2018
    Wakefield
    10 Post(s)
    I’ve got the two new boots on the front, a new budget on the rear and one of the original 4 old tyres.
    I do have a spare with another new budget on(purely for a spare)I could put this on and have 4 new tyres but I think I know it’s not the tyres now. I’m changing the spigot rings at the weekend, then it’s gonna have to go in for a proper wheel an suspension check isn’t it
  6. Re: A6 Avant wobbling
    Jul 2007
    glasgow
    35 Post(s)
    going for the new tyres
    swap over the fronts first
    then if that doesn't work, then swap one wheel at a time from front to rear
  7. A6 Avant wobbling
    #17
    Mar 2018
    Wakefield
    10 Post(s)
    Did all this before with the wheel changing when I had the spare done and one tyre replaced.
    Never budged
    I’m thinking a suspension component is worn or a driveshaft damaged
    Who knows, could be in the gearbox
  8. Re: A6 Avant wobbling
    #18
    Aug 2018
    uk
    Im no guru---but its sounding as though just maybe, bottom ball joints one or both-and or controle arms one or all--at that speed the front lightens up just that wee bit, I had a pal with same prob on an A3 and it turned out to be bottom balljoints were f%%%ed once the frnt end lightened up they were mooving in an out just enough too have ya steering left an right at same time-ie-as if car was wobbling at front end, though I do recall it did throw a fault light on dash !!!! I could be completly wrong but worth a check !!! Tho on that yr--I am going for controle arms one or more-at road speeds frnt end planted bt wen making progress its light an then you feel any movement in the joints !!!!
    Last edited by A55; 21-08-2018 at 09:32 PM. Reason: recall of more info,concerning the prob !!
    1 1 0
  9. Re: A6 Avant wobbling
    #19
    Mar 2018
    Wakefield
    10 Post(s)
    Nice one mate thank you
  10. Re: A6 Avant wobbling
    #20
    Aug 2018
    uk
    I will stick ma neck oot on that--I cant think of anything ells it could be !! Wakefield eh, I had an Uncle that lived there for years (dead now) Bill Rae Motorcycles - dead yrs ago !! Ps--on a car like that--dont go putting on cheep sh%%e rubber cause ya just kidding youself on that it be ok !!!
  1. Please Help wobbling vibration through car! advice needed
    By battmiceter in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-03-2013, 05:05 PM
  2. Crank shaft pulley wobbling
    By vw_golf_nutter in forum Golf MK3 - 1993 - 1999
    Last Post: 22-11-2012, 05:54 PM
  3. Wobbling steering on 51 plate 1.4
    By toby01 in forum Fabia
    Last Post: 21-09-2012, 08:13 AM
  4. wobbling
    By vinnyrowan in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-03-2010, 07:29 PM
  5. wobbling/seasick?
    By Peter Foster in forum Audi A4 - Archive Topics
    Last Post: 16-03-2007, 09:02 PM
