Thread: Rear brakes rubbing after new discs and pads??
  1. Rear brakes rubbing after new discs and pads??
    Jan 2017
    Berkshire
    Hi all. I have a B5.5 TDI 100. I had some warped rear discs so got new discs and pads fitted. I wound the rear pistons back in fully and when fitting the pads cleaned and greased the sliders. Also took the slider bolts out and cleaned and greased them and checked for movement and they could be moved off the discs by hand.
    This was 2 weeks ago and since applying the brakes the first time there is a constant scraping on both wheels as if the pads are constantly on. I can take the calipers off push them off the discs re assemble the wheels and then after a braking session it’s badk to where it was.
    Any ideas??? This happened shortly after I did an emergency stop and had the abs cut in. Are the rear calipers potentionally stuck on and new ones needed?
    I’ve seen some rear calipers on eBay for £30 each but that seems too cheap for them to be any good surely?
  2. Re: Rear brakes rubbing after new discs and pads??
    Jan 2017
    Berkshire
    Quote Originally Posted by Riknos View Post
    Just a quick update on this, for anyone finding this post in a few years time and hate these things going unresolved:
    • Disconnected handbrake cables - no difference, rules out handbrake
    • pushed pistons all the way out - no corrosion, seemed fine, lubed them up with some brake fluid anyway
    • Filed the **** out of the caliper carrier slider surfaces that come into contact with the pads (pads were already filed), and caked them in copper grease - this worked!
  1. Allroad rear brakes binding after new discs and pads
    By Jdot in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-11-2015, 07:11 AM
  2. Please Help Changed brake pads discs and calipers...brakes not working
    By Jacqui1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-06-2015, 07:25 AM
  3. No brakes after new calliper, pads and discs
    By liamthecoder in forum Golf MK4 - 1999 - 2004
    Last Post: 04-01-2013, 10:57 PM
  4. 'Check brakes' warning after replacing discs and pads.
    By Eugheugh in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-11-2012, 10:05 AM
  5. new brakes discs and pads
    By chrismac10 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-07-2009, 11:21 AM
