Thread: Flashig/beeping oil light 2001 1800 Turbo 20VT
  1. Flashig/beeping oil light 2001 1800 Turbo 20VT
    Mar 2009
    Newton Swansea
    Seat Alhambra 20VT 2001
    On a long journey, got stuck in traffic queue, oil warning lamp blinked with beeps could not stop solid 2 lanes no pull off, kept going slowly light coming & going engine was fine stopped at services oil a bit low on dip stick. I topped up ran engine no obvious noises engine fine. Continued journey 80+ miles more light flashing beeps occasionally, but running fine. Got RAC to check, very deep scan only problems DTC's 17852 EGR valve, 16500 coolant temp circuit range/performance problem. Engine running fine.Codes deleted.
    Next had to travel initially no light but came on when slowing down after longer fast run. Seems to be a temperature 'thing' (gauge temp 90 degs no higher) 500 mile on no problem apart from light. Problem now to track down the sensor causing the 'lamp signal' any ideas?
  2. Re: Flashig/beeping oil light 2001 1800 Turbo 20VT
    Mar 2009
    Newton Swansea
    Fixed it the Level sensor in the sump was dodgy replaced it & the problem solved!
  1. Please Help 2001 Alhambra 20VT big flat spot
    By KeithOT in forum Alhambra
    Last Post: 28-02-2015, 02:32 PM
  2. 2001 20VT Spline RH drive shaft
    Last Post: 03-10-2014, 12:11 PM
  3. Red flashig oil light Audi A3 2.0T FSI 2006
    By terryanddeb in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-06-2013, 02:54 PM
  4. Rear Silencer for 2001 20VT
    Last Post: 11-10-2012, 06:29 PM
  5. Flashig Heater plug light
    By squelchy in forum The Commercial Range
    Last Post: 17-02-2009, 04:17 PM
