Thread: Camber - something bent
  1. Camber - something bent
    Jun 2018
    Lincolnshire
    Hi all,
    Ive recently had my new a3 in for tracking,
    The bloke could not track the car as the camber on the passenger front wheel was way out, ( must of had a knock on that side )
    The car has around 2-3 negitive camber showing on the passenger only. The drivers side was spot on,
    Looking at the car from a straight view you can see the wheel is slightly tucked into the arch on that side. I only noticed wen i put my 18in alloys on and at that time thought camber was adjustable on the front of the a3 8p,
    Wen looking about there is nothing i can see thats bent,
    The passenger inner tyre is closer to the shock than the drivers,
    Question is, would the strut being bent cause this or the hub or both?
    If the subframe had moved ad of thought that both sides would be out of camber ect,
    Any info will be a great help
  2. Re: Camber - something bent
    Jun 2018
    Lincolnshire
    Had the tape measure out at both hubs today, there is a 3-4mm differnce each side between the rotor and hub bracket for the strut, so looks to be the hub.
  1. what's bent?
    By dieselal in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-02-2012, 10:40 AM
  2. bent bottom arm?..
    Last Post: 22-01-2012, 03:19 PM
  3. Are my top arms bent?
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-11-2009, 05:36 PM
  4. Bent sub frame
    By Herod in forum Golf MK4 - 1999 - 2004
    Last Post: 18-05-2009, 09:11 PM
  5. Bent wishbone
    By a-f in forum Audi A3 - Archive Topics
    Last Post: 17-04-2009, 02:10 PM
