Thread: Front Suspension CLICK or a CLONK
Results 1 to 10 of 16
  1. Front Suspension CLICK or a CLONK
    Jun 2014
    newport, s wales
    Hi
    Im still trying to cure an annoying click from the front offside suspension of my Avant 1.9 TDI
    I recently changed the front offside wheel bearing which cured the obvious rumbling
    However car has creaks and groans for a while prior to the bearing change
    i cant get it to make a noise when car is jacked up and all ball joints examined no play in joints.
    However i thought the rubber bushes looked a bit tired
    therefore i have changed the two bottom arms
    i have changed the 2 top arms
    the creaking seems to have gone, but not the clunks
    i changed the drop links about 2 years ago, so i dont think they are causing it
    i have placed the car on wooden blocks and had my wife rocking the steering when stationary without any noises
    but as soon as i drive off and "twitch " the wheel click
    can anyone suggest where next please?
  2. Re: Front Suspension CLICK or a CLONK
    18 Post(s)
    454 Post(s)
    When you tightened up the arm bushing points, did you do this with the suspension loaded at ride height or fully dropped at damper max extension? Have you had the strut apart, i.e. spring off? Did you replace every single bolt and nut you removed?
  3. Re: Front Suspension CLICK or a CLONK
    Jun 2014
    newport, s wales
    Hi and thanks for reading my post
    when I replaced top arms I tighten them into position as detailed in Haynes manual
    i.e 1 at 82mm and the other at 70mm from top of strut. Strut was removed to replace them
    the bottom 2 were changed with car off the ground with strut fully extended
    all bolts changed.
  4. Re: Front Suspension CLICK or a CLONK
    18 Post(s)
    454 Post(s)
    You did the top two correctly although the figures sound odd but as I am at home I can’t check them.
    So the strut has not been dismantled to your knowledge?
    The idea of the procedure for the top arms is to simulate their position when at normal ride height, what you have done with the lower inner bushes is to tighten them up unloaded and then when you put the car on the floor they are then twisted around like the car has another car sitting on top of it and then when you drive they are twisted even further and this quickly destroys them.
  5. Re: Front Suspension CLICK or a CLONK
    Jun 2014
    newport, s wales
    Hi again
    i understand what you are saying
    so presumably I could place the car on axle stands, slacken bolts in lower arms
    then raise the hub to the correct height as if stood on ground (measured from wheel arch to hub centre?)
    then re-tighten the lower arm bolts.
    if you can confirm sequence I’ll give that a try tonight
    question can the seats above below the spring cause an issue like this?
    i can see in euro parts web site the top seating is a replaceable item
    havent tried that as I haven’t got a spring compressor YET ��
  6. Re: Front Suspension CLICK or a CLONK
    Jun 2014
    newport, s wales
    I jacked up vehicle and slackened all bottom arm bushes, bottom strut bolts (both sides)
    also both drop links and anti roll bar mounts
    placed car on wooden sleepers under all 4 wheels to create height for access
    retightened all bolts
    car is now much better, creaks and groans have gone. So many thanks Crasher for your replys
    still get an intermittent click. Appears to be on drivers side
    any other pointers would be appreciated
  7. Re: Front Suspension CLICK or a CLONK
    18 Post(s)
    454 Post(s)
    Now you need to replace the bolts if you value your health
  8. Re: Front Suspension CLICK or a CLONK
    Jun 2014
    newport, s wales
    Hi Crasher
    advice received thanks
    all bolts changed this morning (again)
    peace of mind
    cheers
  9. Re: Front Suspension CLICK or a CLONK
    Jan 2009
    Birmingham
    18 Post(s)
    so did it fix the click/clunk you were getting
  10. Re: Front Suspension CLICK or a CLONK
    Jun 2014
    newport, s wales
    Hi there
    hard to say
    all the loud ones gone. Creaks and groans gone
    still getting a slight noise very intermittently
    difficult to describe but it sounds metallic . Spring ?
    not sure, but much better than when I started
    I’ll have another look after I’ve done a job on my sons A3. See new post and please comment/advise if you can
    thanks
  1. A4 Avant Front suspension clunk/click
    By Sullydog in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-10-2014, 10:58 PM
  2. Replies: 3
    Last Post: 10-06-2010, 06:43 PM
  3. Drivers front clonk!
    By rgvn in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-05-2010, 11:02 PM
  4. Suspension clonk
    By Worf in forum 80 - 90
    Last Post: 06-12-2009, 11:36 AM
  5. beetle suspension knock clonk
    By ZIPPYB in forum Beetle 2000-
    Last Post: 27-02-2008, 11:18 PM
