Thread: Front Suspension CLICK or a CLONK
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Front Suspension CLICK or a CLONK
    Jun 2014
    newport, s wales
    Well the clunk has returned with a vengeance
    i took the car to my regular MOT centre
    placed car on the ramp positioned on the circular pads for checking the steering joints etc
    rocked steering wheel from side to side with no noise heard
    road tested the car and CLICK
    my theory was , while on the ramp using the circular pads under the wheels any strain on the steering gear is minimal compared to turning under normal use
    as I have changed all suspension arms , I decided to change the complete strut assembly if only to eliminate any of the component parts.
    as suspected no change, so now I'm edging towards the steering rack.
    does anyone know of any issues with the rack that shows up as a clunk click issue?
    also are all the racks in the B6 variation models of A4 the same? If not what part number should I search for?
    will a rack from a B7 be a direct swap
    my car is 1.9 tdi Avant 130 bhp 2003 plate
    thanks
  2. Re: Front Suspension CLICK or a CLONK
    Jan 2009
    Birmingham
    35 Post(s)
    Did you check the subframe I’ve read on a few forums about the subframe coming apart because it was not welded at factory just folded/crimped have a look at that first try some clamps on it and take it for a drive see if any noise still there
  3. Re: Front Suspension CLICK or a CLONK
    Jun 2014
    newport, s wales
    thanks for the reply
    must admit I wouldn’t have thought of a subframe issue
    but now I will look in that area before I tackle the rack
    a few years ago I had a perished gearbox mount at the rear of the automatic box
    pig to change but cured a different noise
    ill take it to amates place and get it over a pit
    cheers
  4. Re: Front Suspension CLICK or a CLONK
    Jan 2009
    Birmingham
    35 Post(s)
    Have a a look around here
  5. Re: Front Suspension CLICK or a CLONK
    Jun 2014
    newport, s wales
    Ok Fitted the new kitchen so back to a proper problem.
    Checked subframe nothing obvious.
    So to recap.
    I started by changing a wheel bearing (noisy and cured that issue)
    Gradually i started to hear a clonk/click from drivers side wheel area.
    Since then ive changed top arms (one of them twice as the bush slipped out)
    Both bottom arms have been changed within last 2 months.
    I have changed the strut complete with another from a breaker with same colour code on spring.
    IT IS STILL CLUNKING!
    Noise can only be heard when moving, no noise if twitching the steering wheel while stationary
    Car drives well other than this.
    I did consider changing the rack, but i cant convince myself.
    i have considered getting a complete strut,hub and arms assembly from a breaker. I am at my wits end as to what to try.
    Can anyone suggest something else PLEASE?
    cheers
  6. Re: Front Suspension CLICK or a CLONK
    Jun 2014
    newport, s wales
    If anyone is interested, or having similar issues, i have sorted my problem
    I had to get a new tyre fitted and while i was there i asked for an opinion on the clonk.
    The bloke was huge and when he pulled the wheel, he managed to get the car to make a clunk noise.
    i was under the car listening and the noise appeared to be coming from within the hub assembly
    I obtained a knuckle joint with a hub complete with a driveshaft from a breaker in Cardiff
    Fitted it to the car without separating the drive shaft. Used all my suspension arms , strut ,disc and caliper etc.
    NOISES ALL GONE
    its like having a different car.
  1. A4 Avant Front suspension clunk/click
    By Sullydog in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-10-2014, 10:58 PM
  2. Replies: 3
    Last Post: 10-06-2010, 06:43 PM
  3. Drivers front clonk!
    By rgvn in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-05-2010, 11:02 PM
  4. Suspension clonk
    By Worf in forum 80 - 90
    Last Post: 06-12-2009, 11:36 AM
  5. beetle suspension knock clonk
    By ZIPPYB in forum Beetle 2000-
    Last Post: 27-02-2008, 11:18 PM
