Thread: Audi A6 C7 gear issue, lever in park but car thinks its in drive ?
  1. Audi A6 C7 gear issue, lever in park but car thinks its in drive ?
    Aug 2016
    Hi Everyone,
    Car was involved in a minor accident (~7mph into bollard) and engine shut off. The automatic lever is in park but the car is saying its in drive and preventing the engine from being switched on. I have manually moved the gearbox lever into neutral and then park again but still the car is saying place the lever into park.
    I have a VCDS report of the issue. Its saying the No Communication with Transmission Control Module? What might be causing this issue?
    Your help on the issue is much appreaciated.
    Code:
    Thursday,19,July,2018,02:32:43:64250
    VCDS Version: 18.2.1.2 (x64)
    Data version: 20180518 DS287.1
    www.Ross-Tech.com
    VIN: WAUZZZ4G   License Plate: Audi A6 C7 AVANT
    Mileage: 13688km-8505mi   Repair Order:
    Chassis Type: 4G-AU57 (4G5)
    Scan: 01 02 03 05 08 09 15 16 17 19 20 28 36 3B 42 44 46 52 53 55
              5F 62 6D 72 AC
    VIN: WAUZZZ4G   Mileage: 13688km-8505miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Cannot be reached 0100
    05-Acc/Start Auth. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    20-High Beam Assist. -- Status: OK 0000
    28-HVAC, Rear -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: Malfunction 0010
    5F-Information Electr. -- Status: OK 0000
    6D-Trunk Elect. -- Status: Malfunction 0010
    AC-Reductant Control -- Status: OK 0000
    Address 01: Engine (J623-DDDA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 HA    HW: 04L 907 309 AA
       Component: R4 2.0l TDI   H20 3830
       Revision: 8DH20---
       Coding: 12254012242401080000
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ECM20TDI01104L906021HA 004003
       ROD: EV_ECM20TDI01104L906021HA_004.rod
       VCID: 6BDFDD40827F0A1CE2-803E
    4 Faults Found:
    21605 - Sensor for Ambient Air Temperature (G17)
              P0070 00 [039] - Malfunction
              Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:40
                        Engine speed: 0.00 /min
                        Normed load value: 0.0 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 24 °C
                        Intake air temperature: 26 °C
                        Ambient air pressure: 1010 mbar
                        Voltage terminal 30: 10.980 V
                        Unlearning counter according OBD: 40
                        Turbocharger 1 turbine inlet: temp. sensor 1 bank 1: raw value: 27.8 °C
                        Turbocharger 1 turbine outlet: temp. sensor 1 bank 1: raw value: 27.8 °C
                        Particle filt.inlet temp.sens.1 bank 1: raw value: 27.8 °C
                        Particle filter outlet temp.sens.1 bank 1: raw value: 27.8 °C
                        Shut-off timer: last engine shut-off time: 2 s
    18837 - Coolant Pump for Intercooler
              P16BA 00 [039] - Running Dry
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 4
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:45
                        Voltage terminal 30: 10.920 V
                        Air mass at air mass meter 1: 0.0 kg/h
                        Extern.temp.sens.1 bank 1: raw value: 3003.6 °C
                        Intake air temperature before throttle valve: calculated: 0.0 K
                        Charge air cool.output temp.sens.1 bank 1: raw value: 24.7 °C
                        Heater supp.pump 1 bank 1 charg.air cool.circuit: activat.: 95.00 %
                        Turbocharg. 1 compressor outlet:temp.sensor 1 bank 1: raw value: 25.9 °C
    4718 - No Communication with Transmission Control Module
              U0101 00 [167] - -
              MIL ON - Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:40
                        Voltage terminal 30: 10.940 V
                        Requested transmission torque: 1000.0 Nm
                        Limitation: accelerator pedal: 126.6 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 44
                        selected gear-Bits 0-7: 0
                        Engine control module reset status-Bits 0-7: 0
                        Transmission torque intervention status-Bits 0-7: 0
                        Transmission torque intervention status-Bits 0-7: 2
                        Calculated reducing transmission intervention torque: 1000.0 Nm
    28991 - No Communications with NOX Sensor 1
              U029D 00 [039] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:40
                        CAN status - engine control module-Bits 0-7: 0
                        CAN status - transmission control module-Bits 0-7: 8
                        CAN status - brake control module 1-Bits 0-7: 0
                        CAN status - brake control module 2-Bits 0-7: 0
    Readiness: 0 0 0 0 1
    Address 02: Auto Trans
    Cannot be reached
    Address 03: ABS Brakes (J104)       Labels: Redir Fail!
       Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
       Component: ESP9 Premium  H01 0530
       Revision: --------    Serial number: --------------
       Coding: 06A29E41604579829B00
       ASAM Dataset: EV_ESP9BOSCHAU57X 004018
       ROD: EV_ESP9BOSCHAU57X.rod
       VCID: 41835FE8D073304C68-8014
    10 Faults Found:
    14848 - Function Restricted due to Missing Message(s)
              U1111 00 [047] - -
              [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:46
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        Uz: 8C
    15360 - Function Restricted due to Missing Message(s)
              U1111 00 [047] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:46
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        Uz: 8C
    15616 - Function Restricted due to Missing Message(s)
              U1111 00 [047] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:46
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        Uz: 8C
    124416 - Function Restriction due to Faults in Other Modules
              U1113 00 [047] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:46
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        Uz: 8C
    218880 - Function Restriction due to Implausible Message(s)
              U1112 00 [035] - -
    209920 - Function Restriction due to Implausible Message(s)
              U1112 00 [035] - -
    182528 - Function Restriction due to Implausible Message(s)
              U1112 00 [035] - -
    183040 - Function Restriction due to Implausible Message(s)
              U1112 00 [035] - -
    183296 - Function Restriction due to Faults in Other Modules
              U1113 00 [047] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:46
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        Uz: 8C
    183552 - Function Restriction due to Implausible Message(s)
              U1112 00 [035] - -
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
       Component: BCM2 2.0      H61 0825
       Revision: 00002001
       Coding: 01B9704E000000000000
       VCID: 7CFDEE1CFF119DA47B-8028
       Subsystem 2 - Part No SW: 4H0 905 852 C    HW: 4H0 905 852 C
       Component: J764 ELV MLB  H40 0046
       Serial number: 3216000299601001
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
                013 - Check DTC Memory
                 Freeze Frame:
                        Fault Status: 01101101
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Time Indication: 0
                        Date: 2018.07.01
                        Time: 01:26:48
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-4Z.clb
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Component: KLIMA 4 ZONEN H14 0113
       Serial number: 11011700041237
       Coding: 34220978210000
       ASAM Dataset: EV_AirCondiComfoUDS 003008
       ROD: EV_AirCondiComfoUDS_003.rod
       VCID: 63CFB5606AAF425C5A-8036
    5 Faults Found:
    0243 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:49
                        Voltage terminal 30: 10.98 V
                        Outside air temperature: 77.5 °C
                        Engine speed: 0 /min
    0276 - Engine Off Timer Performance
              P150A 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:46
                        Voltage terminal 30: 11.04 V
                        Terminal 15 status: Terminal 15 on
    0387 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 6
                        Reset counter: 228
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:46
                        Voltage terminal 30: 11.05 V
    0388 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:46
    0554 - Function limitation due to crash signal
              B1397 00 [009] -  -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:46
    Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
       Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
       Component: BCM1 2.0      H20 0368
       Revision: 15020001    Serial number: 00001558178001
       Coding: 0105001440349FE041014083800018000F9DC7082F08020100000894E100140200400024030000
       VCID: 74EDC63CD741D5E433-8020
       Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS57X 161102  H38 0080
       Serial number:         161118232837
       Coding: 0045F7
       Subsystem 2 - Part No SW: 81A 955 547 A    HW: 81A 955 547
       Component: G397_RLFS  H06 0002
       Serial number: 20057467X81A955547A0
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
       Component: E1 - LDS  H07 0044
       Serial number: 14 12 2016  00000785
       Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H01 0006
       Serial number: 1AB8026800PAG0MUFU03
    8 Faults Found:
    00779 - Outside Air Temp Sensor (G17)
                012 - Electrical Fault in Circuit
                 Freeze Frame:
                        Fault Status: 01101100
                        Fault Priority: 2
                        Fault Frequency: 17
                        Reset counter: 228
                        Mileage: 13688 km
                        Time Indication: 0
                        Date: 2018.07.01
                        Time: 01:26:49
    00256 - A/C Pressure/Temperature Sensor (G395)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Time Indication: 0
                        Date: 2018.07.01
                        Time: 01:26:49
    01315 - Transmission Control Module
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Time Indication: 0
                        Date: 2018.07.01
                        Time: 01:26:50
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Time Indication: 0
                        Date: 2018.07.01
                        Time: 01:26:51
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Time Indication: 0
                        Date: 2018.07.01
                        Time: 01:26:51
    03455 - Function Restriction due to Faults in Other Modules
                000 -  -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Time Indication: 0
                        Date: 2018.07.01
                        Time: 01:26:52
    01493 - Bulb for Blinkers; Front Left (M5)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Time Indication: 0
                        Date: 2018.07.01
                        Time: 01:27:59
    01497 - Bulb for Blinkers; Front Right (M7)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Time Indication: 0
                        Date: 2018.07.01
                        Time: 01:27:59
    Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0092
       Revision: --------    Serial number: 003P100CBBP2
       Coding: 30333130313630323639554A305234473053
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
       ROD: EV_AirbaAU10BPAAU64X_VW51.rod
       VCID: 3B7F2D00B29F5A9C32-806E
       Crash sensor for side airbag: driver side:
       Serial number: 3575HRB405L480GQ3H29
       Crash sensor for side airbag: front passenger side:
       Serial number: 3585HRB405L480GQAH1G
       Crash sensor for side airbag: rear: driver side:
       Serial number: 3515JRB401A57IFCAHHF
       Crash sensor for side airbag: rear: passenger side:
       Serial number: 3525JRB401457IFCB24Q
    14 Faults Found:
    9443861 - Driver's Front Airbag Crash Sensor
              B101A 15 [137] - Open or Short to Plus
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:49
    9444117 - Front Passenger's Front Airbag Crash Sensor
              B101B 15 [137] - Open or Short to Plus
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:49
    9437201 - Igniter for Driver's Airbag
              B1000 11 [137] - Short to Ground
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:51
    9437723 - Igniter for Passenger's Airbag
              B1002 1B [137] - Resistance Too High
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:51
    9571866 - Ignitor for Drivers Airbag Release Valve
              B120E 1A [137] - Resistance Too Low
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:51
    9572123 - Ignitor for Passenger Airbag Release Valve
              B120F 1B [137] - Resistance Too High
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:51
    9442587 - Igniter for battery interrupt
              B1015 1B [137] - Resistance Too High
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:51
    9442075 - Driver's Belt Force Limiter Igniter
              B1013 1B [137] - Resistance Too High
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:51
    9442331 - Passenger's Belt Force Limiter Igniter
              B1014 1B [137] - Resistance Too High
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:51
    9438747 - Igniter for Seat Belt Tensioner; Driver's Side
              B1006 1B [137] - Resistance Too High
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:51
    9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
              B1007 1B [137] - Resistance Too High
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:51
    9438491 - Igniter for Driver head airbag
              B1005 1B [137] - Resistance Too High
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:51
    9438235 - Igniter for Front passenger's Head Curtain Airbag
              B1004 1B [137] - Resistance Too High
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:51
    1049862 - Databus
              U1123 00 [009] - Received Error Message
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:47
    Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
       Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
       Component: Lenks.Modul   H06 0005
       Revision: C0068538    Serial number: 91560QA4000TE
       Coding: 000035
       VCID: 3B7F2D00BA9F5A9C32-806E
       Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
       Component: E221 - MFL  H08 0010
       Serial number: 07 11 2016  D0013650
    No fault code found.
    Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
       Part No SW: 4G8 920 951 E    HW: 4G8 920 951 E
       Component: MDieGb        H43 0604
       Revision: 32450309    Serial number: 658151216592003
       Coding: 33A615000B412600010000
       ASAM Dataset: EV_RBC7KMID 004050
       ROD: EV_RBC7KMID.rod
       VCID: 3261002465D59BD4E1-8066
    1 Fault Found:
    16776976 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:50:55
    Address 19: CAN Gateway (J533)       Labels: None
       Part No SW: 4G5 907 468 H    HW: 4G0 907 468 AC
       Component: J533--Gateway H15 0096
       Revision: --------    Serial number: 00000002487869
       Coding: C0CD074418
       ASAM Dataset: EV_GatewPkoUDS 002000
       ROD: EV_GatewPkoUDS_002.rod
       VCID: 3A712804BDA5639429-806E
       Battery Monitoring Control Module:
       Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
       Component: J367-BDMHella  H10 9070
       Serial number: 3665852404
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
       Component: J532_DCDCStab  H23 0022
       Serial number: 16092100000000000775
    3 Faults Found:
    4226 - No Communication with Transmission Control Module
              U0101 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:47
                        Voltage terminal 30: 10.7 V
                        Voltage terminal 15: 10.7 V
                        Control Module temperature: 33 °C
                        System status: Terminal 15 on
                        IN ESP_standstill flag: standstill detected
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status via CAN: On
                        Terminal 15 status: On
                        Datenfeld: 0
    6657 - Generator
              U1052 00 [009] - No Communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 02:03:00
                        Control Module temperature: 29 °C
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    12291 - Energy Management Active
              U140B 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 8
                        Reset counter: 228
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:47
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 2
    Address 20: High Beam Assist. (J844)       Labels: None
       Part No SW: 4H0 857 511     HW: 4H0 857 511
       Component: FLA           H04 0021
       Revision: AA001002
       Coding: 04028264747464545425363E00
       VCID: 67D7A17096972E7C86-8032
    Address 28: HVAC, Rear (E265)       Labels:| 4G0-919-158.clb
       Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
       Component: KLIMA FOND    H08 0113
       Serial number: 03011700040942
       Coding: 22
       ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
       ROD: EV_ClimaContrUnitRearUDS_003.rod
       VCID: 3D7B2318AC8B54AC0C-8068
    Address 36: Seat Mem. Drvr (J136)       Labels: None
       Part No SW: 4G8 959 760     HW: 4G8 959 760
       Component: MEM-FS        H03 0157
       Revision: AA000000    Serial number: 00000230404703
       Coding: 0078130000006001000001010101102030303232203232
       VCID: 77F7F130C637BEFC16-8022
    Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
       Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
       Component: SARA 3D       H04 0056
       Revision: --------    Serial number: EJ1BPA720UURRV
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 336F05209ACF92DCEA-8066
    Address 42: Door Elect, Driver (J386)       Labels: None
       Part No SW: 4G8 959 793 J    HW: 4G8 959 793 G
       Component: TSG FA        H03 0511
       Coding: 011C16015E01620002080002
       VCID: 479741F0F6570E7CA6-8012
    Address 44: Steering Assist (J500)       Labels:| 4G0-909-144.clb
       Part No SW: 4G0 909 144 T    HW: 4G0 909 144 Q
       Component: RCevo         H54 0202
       Revision: 00000002    Serial number: 0000537341
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
    Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0428733407
       Coding: 013B0622A0B93080C320098400010F470000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177 B
       Component: Sensor, DWA  005 0002
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
       Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
       Component: Dachelektroni  H10 0100
       Serial number: 0000000AP00027881295
       Coding: 010000
    2 Faults Found:
    01317 - Control Module in Instrument Cluster (J285)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 23
                        Reset counter: 228
                        Mileage: 13688 km
                        Time Indication: 0
                        Date: 2018.07.01
                        Time: 01:26:51
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Time Indication: 0
                        Date: 2018.07.01
                        Time: 01:26:47
    Address 52: Door Elect, Pass. (J387)       Labels: None
       Part No SW: 4G8 959 792 J    HW: 4G8 959 792 G
       Component: TSG BF        H03 0511
       VCID: 46894CF4F15D17745D-8012
    Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
       Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
       Component: EPB-4         H01 0018
       Revision: --------    Serial number: 00000002063940
       ASAM Dataset: EV_ParkiBrake 001033
       ROD: EV_ParkiBrake_VW51.rod
    3 Faults Found:
    329728 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:49
                        Voltage terminal 30: 11.0 V
                        Internal Fault ID: 94
                        Network management state: normal
                        Function light in parking brake button: OFF
                        Red operating lamp: OFF
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        ACC requested apply: not active
                        Auto Adjust: not active
                        General Inspection Function: not active
                        Internal Parking Brake state: static
                        Status of parking brake button: Not operated
                        Status ParkingBrake left: Open
                        Status ParkingBrake right: Open
    329984 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:49
                        Internal Fault ID: 95
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    461568 - Function Restriction due to Faults in Other Modules
              U1113 00 [137] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 228
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:50
                        Internal Fault ID: 147
                        Yellow warning lamp: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    Address 55: Headlight Range (J745)       Labels:| 4H4-907-357-V2.clb
       Part No SW: 4H4 907 357 E    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0100
       Coding: 04FE02102A600200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
       ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
       VCID: 346D063C9FC195E4F3-8060
       Led Headlamp Powermodule Left:
       Component: LED LeiMo li.
       Coding: 000000
       Led Headlamp Powermodule Right:
       Component: LED LeiMo re.
       Coding: 000000
    2 Faults Found:
    13706008 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 228
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:55
    13679104 - Local Data Bus
              U10BA 00 [137] - No Communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 7
                        Reset counter: 228
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:50
    Address 5F: Information Electr. (J794)       Labels: Redir Fail!
       Part No SW: 4G1 035 192 F    HW: 4G1 035 192 A
       Component: RMC Nav Plus  H62 0186
       Coding: 010101010141DB47082B060301010000000000
       VCID: 2649EC74511DF7747D-8072
       Subsystem 1 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
       Component: DU6 Basic  H43 0084
       Serial number: 9464K$0G2781032
       Subsystem 2 - Part No SW: 4G2 919 610 E    HW: 4G2 919 610 E
       Component: E380 BDT C7  H20 0250
       Serial number: 90349PL10008O
    Address 62: Door, Rear Left (J388)       Labels: None
       Part No SW: 4G8 959 795 J    HW: 4G8 959 795 G
       Component: TSG HL        H03 0511
       Coding: 010814004001620002080002
       VCID: 499347C8E043F80CB0-801C
    Address 6D: Trunk Elect. (----)       Labels:* Redir Fail!
       Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
       Component: HDSG-Modul    H05 0152
       Revision: 14005001    Serial number: 341602056
       Coding: 093205C010
       ASAM Dataset: EV_HDSGAu572 001022
       ROD: EV_HDSGAu571.rod
       VCID: 36693C3489BD87F4CD-8062
    1 Fault Found:
    0114 - Load Space Cover
              B12EF 54 [137] - Missing Calibration / Basic Setting
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 13688 km
                        Date: 2018.07.01
                        Time: 01:26:48
                        Voltage terminal 30: 11.02 V
    Address 72: Door, Rear Right (J389)       Labels: None
       Component: TSG HR        H03 0511
    Address AC: Reductant Control (J880)       Labels: 4G0-907-355.clb
       Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0013
       Revision: 00000000    Serial number: 163270088
       ASAM Dataset: EV_RDCMA00100 008040
       ROD: EV_RDCMA00100_008.rod
       VCID: 2F67095076E7B63C8E-807A
    End-------------------------(Elapsed Time: 05:38)--------------------------
  2. Re: Audi A6 C7 gear issue, lever in park but car thinks its in drive ?
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi looks like wiring / module damage. Is it the front that has been damaged, if so I would suspect this or something being dislodged. If you can access behind the damaged area you may well find the cause but it could be a needle in a hay stack, to find. Or maybe an impact sensor been activated and shutting stuff down. Hopefully it can be sorted without to much cost, good luck...
    2015 FL S-line 2L ultra & 2003 225 TT Coupe
  1. Automatic Gear Shifter (Selector) stuck in Park - Audi A6 2.0TDI
    By nizzex in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-11-2015, 06:16 PM
  2. DSG Gear Lever
    By thorne in forum Golf Plus
    Last Post: 06-07-2012, 03:35 PM
  3. Please Help Replacing/Removing Golf Mk5 Handbrake Lever Cover & DSG Gear Lever/Surround ?
    By shaft-50 in forum Golf MK5 - 2004 - 2009
    Last Post: 16-05-2009, 04:50 PM
  4. Please Help audi a4 slack in gear lever - help
    By scotchydoodle in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-02-2009, 11:22 PM
  5. Replies: 2
    Last Post: 02-02-2009, 03:08 PM
