Thread: fuel filter change
  1. fuel filter change
    Mar 2007
    9 Post(s)
    Hi all just returned to the audi club after four years in vans . I bought myself an audi 2.0tdi cr a6 avant s line special edition 170 bhp first registered In January 2011 . so I plan to service it on Saturday I noticed that the fuel filter is different from the cars I have had in the past ie a4 this filter is a longish canister with just 0ne pipe in and one out and sits at the rear of the engine I a black steel cage do any of you know the priming procedure for this type of filter . any advice would be appreciated
  2. Re: fuel filter change
    Jul 2013
    76 Post(s)
    Under the black cover is a in out filter.
    Just clamp both hoses and replace the filter.
    Ideally you need VCDS (vag com) to do the priming of the filter by doing a fuel transfer test.
    The owners manual says you could prime the system by just turning over the engine this is dependant on how good the battery is.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: fuel filter change
    Mar 2007
    9 Post(s)
    ok thanks for the reply I have access to vcds so but might just try turning it over seems less messing about
  4. Re: fuel filter change
    Jul 2008
    Lisburn
    15 Post(s)
    Sealey Diesel Fuel System Priming Device Diesel Pump Priming Tool VS055 5024209037259 | eBay seen a you tube of a guy who wrapped a cloth around and air compressor and stuck it into the tank. K.I.S.S ?
  5. Re: fuel filter change
    Jul 2013
    76 Post(s)
    That Sealey primer is good for filters with self sealing fittings.
    The 2.0 TDI CR engine have a filter that just has hoses clamped on to the filter.
    you could use to fill the filter but you will add air into the system when you disconnect the primer.
    Dan
  6. Re: fuel filter change
    Mar 2007
    9 Post(s)
    Hi all so I serviced the car today probably one of the easiest I have ever done oil air fuel and pollen filters changed and oil of course . The pollen filter was a bit of a mare due to its awkward position in the footwell on your back not a comfortable position to be in so all done just one thing I could not figure out how to turn off the service due warning I tried to do it with vcds but no luck . anyone have any idea how to do it
  7. Re: fuel filter change
    Sep 2011
    Kilmarnock, United Kingdom
    12 Post(s)
    Quote Originally Posted by sbt View Post
    Start the engine
    Press the CAR button to get to the service menu
    From there use the bottom left button on the MMI Controller to CAR SYSTEMS
    Scroll to and select SERVICE & CHECKS from the CAR SYSTEMS menu
    Select SERVICE INTERVALS
    Select RESET OIL CHANGE INTERVAL and confirm
    Turn off the ignition and restart to confirm reset is completed
  1. audi a4 fuel filter and air filter change intervals??
    By sps in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-01-2014, 11:24 PM
  2. PD fuel filter change?
    By bk.bas99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-02-2011, 06:59 PM
  3. 130 pd fuel filter change when?
    Last Post: 15-01-2011, 12:15 AM
  4. Please Help Fuel filter change
    By deeb in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-05-2009, 08:22 PM
  5. fuel filter change
    By mf6480 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-04-2009, 06:14 PM
