Thread: Poor Brakes
  1. Poor Brakes
    6 Post(s)
    Hi!
    I currently have my A6 Avant in many parts still as I am doing a full suspension replacement on the front. I am using my trusty ol polo 9n while its off the road so
    while I am on I thought I may as well look at the brakes.
    I had genuine Audi disks and pads that I replaced all round for ebay special 'Drive Tec' discs and pads, I flushed the brake fluid completely with very cheap brake fluid.
    Now my brakes are cr@p, they stop and are not spongy but you have to stamp on the brakes to get it to stop. They have probably done about 10k now.
    I'm guessing it's the pads that makes them poor and not the cheap brake fluid. I was going to just replace the front pads with Pagid ones see if that helps?
    Does the seam sensible? I think the discs should be OK.
  2. Re: Poor Brakes
    Sep 2008
    Highlands
    12 Post(s)
    Quote Originally Posted by robert1z View Post
    Hi!
    I had the same problem .
    i use pagid now and a decent fluid .
    it is probably air though .
    I got advice at the time on the forum and I bought a compressed air bleeder . It made a big difference.
    Also there is a particular order you need to bleed them in .
    Vin
  3. Re: Poor Brakes
    Jan 2019
    Suffolk
    9 Post(s)
    Any idea what that order is?
  4. Re: Poor Brakes
    1840 Post(s)
    Get Padgid on it all round, decent price and bulletproof.
  5. Re: Poor Brakes
    May 2012
    Everywhere
    308 Post(s)
    Nothing special about OE pads .
  6. Re: Poor Brakes
    Aug 2017
    West Midlands UK
    11 Post(s)
    Can't see the discs being a problem but the special 'Drive Tec' pads are probably made up of an inferior friction material and less efficient than even the standard pads.
    If the Drive Tec's are dedicated racing pads they will work better at higher temperatures while racing etc but will be terrible on a leisurely amble around town where they don't build up enough heat.
    As mentioned, Pagid components are very good, been using them for many years without any issues.
    2003 A6 C5 2.5 TDI Quattro Avant (180bhp)
  7. Re: Poor Brakes
    Feb 2019
    Markinch
    As you say it seems it is the type of pad that is the issue, unless you contaminated the disc and pads with fluid whilst fitting which can glaze the pad and reduce effectiveness even after 10K. Would be good if you posted the result of fitting OEM or Pagid pads and how the old pads looked.
  1. Please Help Possible binding brakes responsible for poor MPG???
    By Jonny88 in forum Golf MK4 - 1999 - 2004
    Last Post: 09-03-2011, 10:35 PM
  2. Replies: 0
    Last Post: 26-12-2010, 04:08 PM
  3. A4 2.0 TDI 143 SE: Poor ride, poor seats and no footrest. Anything I can do?
    By wm1 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-05-2010, 11:06 PM
  4. Poor Brakes
    By katie68 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-07-2009, 09:26 PM
  5. Poor brakes and correct bleeding order help...
    By Butters in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-04-2009, 04:27 PM
