Thread: 2004 Polo 9N1 4-door SE model with AXU engine - exhaust temp. sensor
  1. Question 2004 Polo 9N1 4-door SE model with AXU engine - exhaust temp. sensor
    Aug 2008
    Wigan
    9 Post(s)
    Hi, a quick query on a 2004 Polo 9N1 4-door SE model with AXU engine and just over 50,000 miles on it. Whereabouts is the exhaust temperature sensor? I may need to change this; my garage reported faulty after a service. Any clues on the best source for a replacement part would be greatly appreciated.
  2. Re: 2004 Polo 9N1 4-door SE model with AXU engine - exhaust temp. sensor
    Aug 2008
    Wigan
    9 Post(s)
    I've had a look under the air box/filter/cover and I think the exhaust temp sensor is just under the exhaust manifold heat shield on the nearside of the manifold. Is that the right one? If anyone can comment and recommend a good source for a replacement part I'd appreciate it.
  3. Re: 2004 Polo 9N1 4-door SE model with AXU engine - exhaust temp. sensor
    Aug 2008
    Wigan
    9 Post(s)
    I would at least appreciate the correct part code for this sensor.
  4. Re: 2004 Polo 9N1 4-door SE model with AXU engine - exhaust temp. sensor
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    From your description that sounds more like the O2 or Lambda sensor. go to the dealer or TPS warrington to verify the correct part number or take a punt on line LS7359 Bosch Lambda Oxygen Sensor VW Polo 1.4 FSI [9N3] AXU 04.05-07.06 4047024158610 | eBay if you're sure this is at fault. Do you have the check engine light on the dash or any other diagnostics to suggest it is a sensor fault or just word of mouth from the service? As far as I remember from having one of these engines several years ago there is no separate 'exhaust temp sensor'
    Quote Originally Posted by batteryman View Post
  5. Re: 2004 Polo 9N1 4-door SE model with AXU engine - exhaust temp. sensor
    Dec 2014
    Bedford
    42 Post(s)
    There is a exhaust temperature sensor on this engine. 1.4 fsi axu engine . From memory I think it screws into the down pipe. There is also likely to be 2 lambda sensors as well. Quite a rarely used engine in my experience.
  6. Re: 2004 Polo 9N1 4-door SE model with AXU engine - exhaust temp. sensor
    Dec 2014
    Bedford
    42 Post(s)
    If you go onto auto doc there is a few different makes listed.
  1. Passat exhaust temp sensor
    By Nickh2504 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-08-2018, 06:28 AM
  2. Exhaust Gas Temp Sensor
    By Dougster67 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-09-2011, 05:07 PM
  3. Important Can we install polo 9n3's steering wheel to my 2004 model Polo 9N?
    By polo38 in forum Polo - Derby - Lupo - Fox
    Last Post: 28-09-2010, 09:32 PM
  4. URGENT HELP - exhaust/NOX/Gas temp sensor
    By lyndon79 in forum New Member Introductions
    Last Post: 14-12-2009, 03:20 PM
  5. Question Petrol flap on 1.4 Polo - 2004 model
    By mmaritz13 in forum Polo - Derby - Lupo - Fox
    Last Post: 23-01-2009, 10:42 PM
