Hello everyone,
I am having trouble adapting gearbox for my A4 b8 2.7 tdi multitronic.
In fact I am able to complete the multitronic adaptation but after engine restart the adaptation process starts over again.
Is it normal that adaptation status changes to "running" after engine restart? If no, how can I successfully complete it and save it so after engine restart adaptation status does not change to "running" again?
0AW Self-Diagnosis Clutch Adaptation Instructions
Select the following measured values in the self-diagnosis and possibly save them under Favorites:
^ Adaptation of the forwards start-up behavior [LO] State
^ Adaptation of the backwards start-up behavior [LO] State
^ Transmission fluid temperature
^ Specified clutch torque
Creep adaptation of the forward and reverse clutch with 0AW gearboxes:
1. Make sure that there are no fault entries in the TCM.
2. Warm up the gearbox to about 85C, ideally by pulling away in driving mode D and R at various loads of max 1500 rpm.
Tip: Currently the adaptation is only possible when the measured value transmission temperature is between 80 - 95C.
3. When the vehicle is standing still, select driving mode D.
4. Pull away with little acceleration to about 6 mph or 10 km/h. Slowly brake the vehicle with the foot brake.
Hold the brake pedal for another 5-10 seconds as the vehicle stands still.
5. When stopping, the specified clutch torque must not drop below 20 Nm, otherwise the adaptation fails.*
If this is the case, change the driving profile (less load, gentler braking).
When stopping, the specified clutch torque must not drop below 20 Nm, otherwise the adaptation fails. If this is the case, change the driving profile.
6. Repeat step 4 until the measured value indicates the adaptation of the forwards start-up behavior is successfully completed.
7. With the vehicle standing still, select driving mode R.
8. Repeat step 4 until the measured value indicates adaptation of the backwards start-up behavior is successful completed.
9. After a terminal 15 reset, the adaptation starts over again with status running. Keep the ignition switched on*
for at least six minutes after a successful adaptation .
