Thread: Engine Cooling Fan Problem
  1. Engine Cooling Fan Problem
    Jun 2010
    United Kingdom
    I have a 2004 Audi A8 D3 4.0 TDI
    As soon as I turn on the ignition the high speed engine cooling fan switches on and stay on.
    Running the VCDS I get the following error:
    18080 - Coolant Fan Control 1
    P1672 - 000 - Open or Short to Ground
    Freeze Frame:
    RPM: 651 /min
    Torque: 105.3 Nm
    Speed: 0.0 km/h
    Duty Cycle: 9.9 %
    Voltage: 13.45 V
    Duty Cycle: 9.9 %
    Duty Cycle: 9.9 %
    Temperature: 54.9°C
    Anyone else had this problem and found a cure?
    Any tips for hunting down the cause?
    Many thanks
  2. Re: Engine Cooling Fan Problem
    May 2013
    Wisbech
    8 Post(s)
    Possible fan control module at fault . You will need to swap it , quite common issue in vw /audi group
    Sent from my ONEPLUS A5010 using Tapatalk
  3. Re: Engine Cooling Fan Problem
    Jun 2010
    United Kingdom
    Thanks for that. Much appreciated.
    Is this easily accessible or is it a radiator out and coolant drain situation?
    Many thanks
  4. Re: Engine Cooling Fan Problem
    May 2013
    Wisbech
    8 Post(s)
    Not sure how it is in D3 , but usually module is located near fans , or sometimes is included in fans electronics. Best fallow harness from fan. If it is going straight to ecu then u need to swap fans , if you will find small box then this your module.
    If you need to swap fans then you need dismantle front
  5. Re: Engine Cooling Fan Problem
    Jun 2010
    United Kingdom
    Quote Originally Posted by damtom85 View Post
    Many thanks
    There's not alot I can see with the bonnet up. Does this mean remove the front bumper?
    I've seen some pics with the module attached to the fan so may mean I have to replace the lot, or try to swap it out if theres a way to remove the module on its own.
  6. Re: Engine Cooling Fan Problem
    1840 Post(s)
    The fan controller is inside the fan motor or with that fault code you could have a broken data wire. Replacing a fan on these is a full front end strip down with radiator carrier drawn forward into the so called “service position”. There is a bewildering array of fan types so if you private message me your reg number I can try and pin point which one you need BUT they are all around £570.
  1. Engine cooling fan running after I stop the engine after a journey
    By vince47 in forum Passat - B8 Forum - 2015 -
    Last Post: 20-05-2016, 09:01 PM
  2. engine cooling fan
    By big x in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-07-2010, 11:10 AM
  3. A6 cooling problem
    By firefox in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 04-10-2008, 10:50 AM
  4. cooling fan problem
    By afox101 in forum Golf MK5 - 2004 - 2009
    Last Post: 20-03-2008, 11:59 PM
  5. A3 Cooling Fan Problem
    By MOTOW in forum Audi A3 - Archive Topics
    Last Post: 10-10-2007, 09:05 PM
