Thread: Passat 2.0tdi A/C not working
  1. Passat 2.0tdi A/C not working
    Jul 2018
    Fleet, hampshire
    Hi all,
    I am having issues with my a/c on my Passat estate 2.0tdi. Iv seen quiet a few threads on ac issues but havnt been able to find one to help me. I will list issues & fault findings so far & hopefully someone can help me out.
    First I checked to compressor & noticed the pulley was damaged, I ordered a recon (hopefully not faulty)got the Freon de gassed & fitted the new compressor. I checked to connector to the solinoid which was showing about 8v?. I then supplied power to the solinoid which you could hear engaging tho I know this is not 100% proof test. The car was re gassed but still no ac. The garage said a fault code for the pressure sensor showed. I changed the sensor behind the drivers light & still no ac. I checked the connect power supply & no power was delivered with the ac on or off. Is this normal? I'm not sure on fuse & relay(if used) locations? I also know the ac button light does display on when pressed, the blowers work, the aux & main fans do not engage when ac button is pressed. Any other advice or fault finding would be much appreciated
  2. Re: Passat 2.0tdi A/C not working
    Aug 2018
    Chester
    Hi there
    Did you get to the bottom of this? Assuming your system isn’t leaking, have you checked:
    - Does compressor clutch engage when you press the AC button on
    - Has the garage that did the regas top up the system to the correct pressure?
    - You mentioned that the aux fan doesn’t engage at all. Have you checked all the fuse?
  1. Replies: 6
    Last Post: 20-11-2018, 02:52 PM
  2. Audi q7 2008 3.0tdi drivers side wiper not working
    By 786sam in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 01-04-2016, 12:44 PM
  3. Audi a3 8p 2.0tdi bkd a/c not working
    By Martynas26 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-10-2014, 02:01 PM
  4. Are A4 2.0TDI's as bad as Passat 2.0TDI's?
    By rallyfreaks in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-03-2010, 06:18 AM
  5. A3 2.0TDI Alarm not working?
    By mattwezley in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-05-2009, 10:51 PM
