Thread: Alpine i902D-G6 into 2012 Golf 6 : Questions please
Results 1 to 10 of 17
  1. Alpine i902D-G6 into 2012 Golf 6 : Questions please
    May 2013
    Glasgow Area
    Hi there,
    I had this system fitted into my 2012 Golf this week, to replace the very basic RCD310 it came with. This system is expensive, but is meant to fully integrate with the steering wheel, dashboard display and the car's microphone.
    I have the following issues, and my Alpine installer got stuck too.
    1. The car's microphone doesn't work. The instructions say to remove the hands-free kit's fuse to avoid conflicts - but I don't know how to find the fuse - any ideas? I tried just unplugging the box under the driver's seat, but it didn't make the microphone work.
    2. It is meant to integrate with the Navigation display on the dash. I enabled this menu using VCDS, but it doesn't work - it just shows the compass stuck at N.
    The installer may have screwed up, or just not know enough, I'll try to find another one that knows what they're doing but in the meantime I'd like to try some stuff myself.
    Any help with this appreciated. There is amazingly little information online about this system, considering its developed by Alpine specifically for the car, I thought it was just a brilliant answer to bring the car up to date.
    Cheers for any help and guidance.,
    - Rob
  2. Re: Alpine i902D-G6 into 2012 Golf 6 : Questions please
    Sep 2018
    Lima, Perú
    Hello Rob, I have the same problem. I installed the Alpine i902D-G6 on my VW Golf R MK6. The original microphone does not work (premium). Did you find a solution?
  3. Re: Alpine i902D-G6 into 2012 Golf 6 : Questions please
    May 2013
    Glasgow Area
    Quote Originally Posted by OAG View Post
    Yes i did! You need to unplug the Bluetooth module under the drivers seat, then connect the wires as shown in the attached.
    Overall I'm very happy with the unit, despite the expense.
    However I've never got the auto dimmer to work, and am not sure if the navigation display is meant to work either. Would appreciate hearing how you've got on with it overall!
  4. Re: Alpine i902D-G6 into 2012 Golf 6 : Questions please
    Sep 2018
    Lima, Perú
    The i902D-G6 is spectacular!
    Despite the cost. I will do what you tell me. I'm frustrated by this inconvenience. I did not find any help. I'll tell you how it went with your recommendations. I thank you very much for your response.
  5. Re: Alpine i902D-G6 into 2012 Golf 6 : Questions please
    Sep 2018
    Lima, Perú
    Hi, I followed your instructions, but it did not work for me. Maybe, the last image of the attachment did not understand it correctly. Do you have to make any additional changes in the connections of the device itself?
    In the i902-G6 model, the navigation system is not functional, we had to acquire the X902D-G6, since it is prepared for navigation (Tom Tom). The i902D-G6, only allows you to see Google Maps, but it does not guide you, on a route. On Wednesday, the 12th of SET will update the Apple IOS to version 12. Car Play, will allow to use the Waze application.
  6. Re: Alpine i902D-G6 into 2012 Golf 6 : Questions please
    May 2013
    Glasgow Area
    You should contact Alpine Support - they were very helpful to me. Good Luck!
    I didn't want built in sat-nav, as I do not believe that is where the future is. I think the future is with Android Auto and Apple Car Play. I use navigation on my i902 every day, via Google Maps or Waze.
    I don't understand why this superb head unit isn't discussed more on this (and other) forums - its a custom bespoke kit by a leading car audio manufacturer, designed specifically for the Golf 6 and Golf 7.
  7. Re: Alpine i902D-G6 into 2012 Golf 6 : Questions please
    Sep 2018
    Lima, Perú
    OK you are right. If I'm lucky, I'll tell you. Thank you very much for your help!
  8. Re: Alpine i902D-G6 into 2012 Golf 6 : Questions please
    Jul 2019
    Mexico
    Hi, I have the same microphone issue, I saw the image but I don’t understand the last step (wires conection) did you find the solution? please letme know, thanks in advance
  9. Re: Alpine i902D-G6 into 2012 Golf 6 : Questions please
    Jul 2019
    Mexico
    Quote Originally Posted by roblightbody View Post
    Hi friend, could you please share the link or the source where you got the images? I’m stuck with the steps 5 and 6... more details will be really appreciated, thanks in advance.
  10. Re: Alpine i902D-G6 into 2012 Golf 6 : Questions please
    May 2013
    Glasgow Area
    Quote Originally Posted by ZamoZarzamora View Post
    I'm sorry I didn't reply sooner. I got it from the excellent Alpine support team.
  1. Does my car have an oil level light? (2012 Golf GT TSI 160).
    By roblightbody in forum Golf MK6 - 2009 - 2013
    Last Post: 18-08-2017, 12:05 PM
  2. Does anyone recognise this part? 2012 Golf Mk6 1.2
    By squonk63 in forum Golf MK6 - 2009 - 2013
    Last Post: 14-09-2015, 12:59 PM
  3. 2012 vw golf 1.6 TDI 105
    By Lyciancag in forum Golf MK6 - 2009 - 2013
    Last Post: 18-04-2015, 07:05 PM
  4. 2012 Polo 1.2 TDI 75 bhp Match (5D) - questions
    By burningoil in forum Polo - Derby - Lupo - Fox
    Last Post: 11-01-2013, 07:02 PM
  5. 2012 - Golf 7 is coming
    By Keithuk in forum Golf MK6 - 2009 - 2013
    Last Post: 06-04-2010, 01:32 PM
