Thread: S-Tronic gearbox oil change
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 37
  1. Re: S-Tronic gearbox oil change
    #21
    Jul 2017
    Maidstone, Kent
    49 Post(s)
    Can you not just turn up at your local audi service centre and ask them nicely to tell you how much oil it should take?
    Audi A6 Avant 2019 Black Edition, C8, 3.0TFSI S Tronic. Tech Pack, Parking Pack, Tow Bar, Tour pack.
  2. Re: S-Tronic gearbox oil change
    #22
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    Quote Originally Posted by gav28uk View Post
    In a way, sort of already done that, as I bought the parts and oil directly from Audi (TPS), against the vehicle's VIN number, and they said 7 Litres.
    Do the service centres even need to know the capacity, as they use a VAS filling machine to pump the oil in until it overflows the fill hole?
  3. Re: S-Tronic gearbox oil change
    #23
    Mar 2014
    Edinburgh
    235 Post(s)
    I reckon the dealers don’t even measure how much came out. It would be open hole and catch it in waste oil bucket then leave it till it stops dripping.
    Time is money in these places so they want to churn out as much as possible.
  4. Re: S-Tronic gearbox oil change
    #24
    Apr 2016
    London/UK
    23 Post(s)
    when i had mine done i was invoiced for 10L but i was told by the mecanic that they are only using half of it
    i was on a fixed priced service so couldn't care much about it
  5. Re: S-Tronic gearbox oil change
    #25
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    Quote Originally Posted by johnro79 View Post
    Half of 10L is 5L!! I think its going to be years before this thread is resolved, it's going like the 'which oil?' thread on the VW T5 forum, that now stands at 548 posts long!!
  6. Re: S-Tronic gearbox oil change
    #26
    Mar 2014
    Edinburgh
    235 Post(s)
    Can you run an air line in the fill hole and blow and see if more comes out the drain? There’s so many mechanical parts and coolers for oil to get stuck in. I think the 7l is for a dry fill like after a rebuild so changes could be a lot less.
  7. Re: S-Tronic gearbox oil change
    #27
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    Quote Originally Posted by A6S View Post
    That's exactly what I was hoping would be the case, I just need someone who can categorically confirm this, with the wet fill capacity. I would always expect the wet fill to be a bit less due to all the oil in the mechatronic and oil cooler, but 2.5 Litres seems excessive, meaning at oil change only 2/3 of the oil is changed.
    As a side thought, could this be why the oil is changed at 40K, and not 80 or 100K?
  8. Re: S-Tronic gearbox oil change
    #28
    May 2008
    Mine was changed at the dealer today - the invoice lists 5l of gearbox oil - mine is the 2.0 fwd so I don’t know if the capacity is different
    hope that helps
    james
    Current - FL A6 Avant 2.0 Ultra BE S-Tronic, Tornado Grey, 20" titanium alloys
    Previous - 2012 - A6 Saloon S-Line 2.0TDI, Daytona Grey, 19" 7 Twin spokes, DAB
    The good ladies - 2014 Golf GT 1.4 TSi ACT - Black
  9. Re: S-Tronic gearbox oil change
    #29
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    I used a gearbox specialist and I`m ex motor trade, plus I didnt want to do that lying on me back! Did you use VCDS and get gearbox temp up to (I think) 50`C and re-check oil level after shifting through gears? I`m sure I`ve read in my ELSA workshop manual that you never actually get the full amount out anyway.
    I`d check you actually have enough in now, live with it, or, take it to a specialist and get it done and sleep well at night.
    Alan.
    VW T6 150 DSG Camper £££
  10. Re: S-Tronic gearbox oil change
    #30
    1836 Post(s)
    Bluezi, I could do with your VIN or reg.
  1. HELP! S-Tronic Gearbox Faults
    By Harmz in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-07-2018, 09:44 PM
  2. Question S-tronic gearbox reliable??
    By AndrewBaciu in forum 2.0T, TSI and TFSI - Engine
    Last Post: 08-03-2018, 11:15 AM
  3. Drive Select & S-Tronic Gearbox
    By skibuddy in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 27-09-2017, 10:48 AM
  4. 64' A7 s-tronic - new gearbox needed!
    By Gizzardman in forum Chat - Anything with wheels
    Last Post: 29-07-2017, 12:28 PM
  5. What gearbox do I have multitronic or S tronic
    By Q7quattro in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 16-05-2015, 08:33 AM
