Thread: ESP Fault with car not starting!
Results 11 to 20 of 24
  1. Re: ESP Fault with car not starting!
    Jul 2018
    Leamington Spa
    Tried coding with soft reset and then without, still no change...
  2. Re: ESP Fault with car not starting!
    Mar 2009
    Montenegro
    13 Post(s)
    The module does not accept coding?
    Did you check fuses? Are they all in order?
    Sent from my LG-D802 using Tapatalk
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  3. Re: ESP Fault with car not starting!
    Jul 2018
    Leamington Spa
    i've checked the fuses, visually, in the ECU compartment, and these all seemed to be ok...
  4. Re: ESP Fault with car not starting!
    Jul 2018
    Leamington Spa
    Right guys, i've managed to book the car for Monday to Audi Stratford on Avon; hopefully it's gonna sort out a way or another...
    I told them the entire story...and they seemed to be pretty conscious of these faults, especially when i told them i've replaced already the battery and fuel pump relay, so hopefully the diagnostics will be focused towards the ECU being fried and others...
    Audi A6 C6 2010 2.0TDI
    Audi A3 8P 2010 2.0TDI
    Mercedes W210 E300TD//OM606
  5. Re: ESP Fault with car not starting!
    Mar 2009
    Montenegro
    13 Post(s)
    Please advise once you have repair it what was the problem. Good luck
  6. Re: ESP Fault with car not starting!
    Jul 2018
    Leamington Spa
    Thanks mate, i'll need some luck!
    I'll keep you guys posted once i'll know anything...
  7. Re: ESP Fault with car not starting!
    #17
    Jul 2018
    Leamington Spa
    Right, no feedback yet with regards to my issues, as the team there(Stratford upon Avon -hope these guys are good-) did not managed to take my car into diagnostics, but weirdly i was asked if i want the new emission software update on it...previously i've said yes(without thinking) but then i had a short browsing session and it seems this software update for emissions would bring allot of unwanted issues like poor performance, increased fuel consumption or DPF cycles up to 4, 5x as much as before, just to name a few...so i called back and told them to hold fire on that one...
    Any of you guys have had this installed? If yes, how is the car performing after the "upgrade"?
  8. Re: ESP Fault with car not starting!
    #18
    Mar 2009
    Montenegro
    13 Post(s)
    I read and saw plenty negative stories. In my counmtry is not compulsory and if in UK is also not compulsory then I will not make it. Leave it like that.
  9. Re: ESP Fault with car not starting!
    #19
    Jul 2018
    Leamington Spa
    Just got of the phone with the guys from Audi and they'll first have to change the steering angle sender unit along with some fuses with no guarantee this will fix it; cost is around £500 + the £60 for diagnostics so far.
  10. Re: ESP Fault with car not starting!
    #20
    Mar 2009
    Montenegro
    13 Post(s)
    Expensive and even not definitive solution. But, no choice
  1. Please Help ESP fault and A3 not starting
    By Becks Rufus in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-06-2014, 04:19 PM
  2. Please Help Starting fault
    By kite in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-06-2012, 02:58 PM
  3. Please Help 2005 TDI Hot Starting Fault
    By nixamus in forum Golf MK5 - 2004 - 2009
    Last Post: 09-02-2009, 10:28 AM
  4. t5 starting fault
    By revmiester in forum The Commercial Range
    Last Post: 07-12-2008, 07:11 PM
  5. Starting Fault
    By RSJMK316V in forum New Member Introductions
    Last Post: 23-04-2008, 11:11 PM
