Thread: total car electronics failure
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: total car electronics failure
    #11
    Mar 2014
    Edinburgh
    201 Post(s)
    20+ years of driving and never had an abs pump go faulty. They are safety items and fairly robust.
    It could be a wire somewhere with a break or a corroded pin on the module.
    Fact that it happened when you start the car still points to a old battery not providing the juice needed for a start and maintaining steady power to all the modules. At least to me anyway.
    Itís also the cheapest part to replace and worth a shot as your car is 7 years old and no record of a battery itís something thatís due anyway. Donít want it failing in middle of winter in the middle of nowhere.
  2. Re: total car electronics failure
    #12
    Jun 2018
    Skopje
    actually all warning lights appeared even before i started the car (ignition on, engine off)... i was planning to scan it with vcds and i hadn't started the engine yet. i realize i misspoke in my previous post when i said "started"
    when i comes to the battery, i can't really notice any hesitation or difficulty when starting the engine, even in sequences of several starts/stops within a period of few minutes. i don't have the impression that the battery is failing tbh...
  3. Re: total car electronics failure
    #13
    Dec 2016
    Ireland
    Just a complete shot in the dark here, but I fixed an intermittent ABS problem on my sisters SEAT, which was caused by a hairline crack in the 30amp fuse on top the battery. Similar to the No. 2 fuse in the picture below, but the crack was much finer, you'd almost have to squint to see it.
  4. Re: total car electronics failure
    #14
    Jun 2018
    Skopje
    so far it seems that i have solved the problem and it seems it was a dirty ABS connector. although the pins looked perfectly clean they probably had some micro layer from the oil vapors/water under the hood. i had the connector cleaned using contact spray and electric circuits cleaner and the problem disappeared. i have driven around 100-150 km since and so far so good.
    this is very strange, however the pins in the connector seem very delicate. the contact area is very small and having an insulating layer between the contacts seems to easily complicate things.
  1. Attention Audi A7 Gearbox Oil Leak Causes Electronics Failure
    By BlakeA7 in forum New Member Introductions - Sponsored by BVR Automotive
    Last Post: 31-10-2017, 08:04 PM
  2. Please Help Complete electronics failure??
    By pcplum in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-04-2017, 08:31 PM
  3. Total dashboard failure
    By Europa25 in forum Passat - B7 Forum 2011 - 2015
    Last Post: 16-11-2013, 10:58 PM
  4. Rear LED OS total failure
    By n1cka8 in forum A8 - S8 - V8
    Last Post: 10-08-2012, 11:35 PM
  5. Total Electrical Failure
    By DAMIENH in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-07-2008, 08:34 PM
