Thread: Anybody with failed oil pump drive ahaft key of 100mm on 2.0 tdi?
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: Anybody with failed oil pump drive ahaft key of 100mm on 2.0 tdi?
    108 Post(s)
    1816 Post(s)
    If VAG had not done away with their excellent dynamic oil pressure monitoring system in circa 1998 then this would be much less of a problem, that early warning system saved a lot of engines from serious damage from 1983 when it was introduced. I watched a video about a chap with a fragged AMG V8 on which he rodded the block on the track, he found it had no oil pressure monitoring system installed, that is supreme engineering arrogance.
  2. Re: Anybody with failed oil pump drive ahaft key of 100mm on 2.0 tdi?
    Mar 2009
    Montenegro
    13 Post(s)
    I did not know anything about that dynamic oil pressure monitoring system on VAG cars (that you mentioned). I found on internet how it functioned. It was realy one additional useful system and it is shame that all modern (even that AMG V8) engines rely on such poor sensor for oil pressure and do not have some sofisticated system to monitor oil pressure during entire rpm range. No need to have gauge but computer can monitore oil pressure and at least you could see it via diagnostic tool.
    Should I instal additional oil pressure gauge?
    Sent from my LG-D802 using Tapatalk
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  3. Re: Anybody with failed oil pump drive ahaft key of 100mm on 2.0 tdi?
    108 Post(s)
    1816 Post(s)
    It would be a useful thing but I do find that when people install aftermarket gauges they start to get obsessed about the reasons, it's why I prefer idiot lights for warnings, sort of ignorance is bliss. That AMG I mentioned I put it slightly incorrectly, it does not even have an oil pressure switch! You can just imagine some up his own **** German engineer thinking "vee arr soo gut at dis dat ve do not need an oil pressure switch because ve are German"
  1. 2.0 TFSI BPJ oil pump failed
    By Andrew3737 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-09-2015, 11:25 AM
  2. ABS pump- FAILED!
    By Redders2 in forum Golf MK5 - 2004 - 2009
    Last Post: 26-09-2011, 09:24 PM
  3. Failed Water Pump??
    By Degsy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-04-2009, 05:34 PM
