Thread: Yellow Engine Light But Carly Clean Diagnostics How to Reset?
  1. Yellow Engine Light But Carly Clean Diagnostics How to Reset?
    Jul 2018
    Surrey
    Hi all,
    Can anyone help me please? My 2012 A5 was asking for oil the other day, and shortly after I put half a litre in the EML came on. I've since downloaded and run Carly on the car and it comes up clean, no diagnostic errors or messages at all. I can only think the oil level changing has triggered the EML for some reason, so how do I reset it?
    If there's something else, why doesn't Carly spot it?
    Many thanks in advance,
    Cheers,
    Jonathan
  2. Re: Yellow Engine Light But Carly Clean Diagnostics How to Reset?
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    If the eml is on there will be a code logged, most likely your diagnostic app is not picking it up. Try and find someone with vcds or a decent obdII scanner.
  3. Re: Yellow Engine Light But Carly Clean Diagnostics How to Reset?
    1841 Post(s)
    Generic readers only pick up OBD II codes and the fault may not be an OBD one.
  1. Yellow engine light
    By peter goble in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-05-2014, 06:04 PM
  2. yellow engine light on.
    By KN006 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-03-2013, 04:01 PM
  3. VCDS diagnostics & airbag light reset - suffolk
    By mathoo19 in forum VCDS - Help Requests
    Last Post: 29-11-2012, 05:25 PM
  4. Yellow Engine Light
    By paul.mgrath in forum Golf MK6 - 2009 - 2013
    Last Post: 26-10-2010, 08:14 PM
  5. Question yellow engine light on....
    By mk1 out2grass in forum Touran - Sharan - Caravelle
    Last Post: 18-08-2009, 05:00 PM
