Thread: Key Coding/Remote learning VCDS vs Dealer
  1. Key Coding/Remote learning VCDS vs Dealer
    Jun 2008
    Hello, I just an a Q7 '07 keyless model with 1 key. Dealer (in France) wants €231 for the key and €95 for coding. I understand they just order keys from factory to the VIN number (key cut). But is the coding the transponder learning/matching or this already done at the factory? ie could I just purchase the key and use VCDS/method for learning the remote RF lock functions. I have a spare 3 button remote, could get a blank ID48 chip and a key cut for €15 but I guess if I ask Audi to code that, they're likely to refuse? Any alternative routes I can consider? thx
  2. Re: Key Coding/Remote learning VCDS vs Dealer
    1836 Post(s)
    In THEORY VCDS can program in a new key IF you have the so called SKC code or PIN code which are different things. In practice I have never been able to do this in 20 years of using VCDS even in the most basic of VAG immobilisers and have had to rely on external help. I now have the full dealer level VAG diagnostic system which is hell to get tied into so I can only see you putting yourself in the hands of a “man in a van” or the main dealer.
  3. Re: Key Coding/Remote learning VCDS vs Dealer
    Jun 2008
    last time I had one was for a A6 C4 and even then had to user alternate method to adapt the key. Will just add this to my to-do list (luckily just found out I am insured for lost keys should the worst happen). thx
  1. Replies: 4
    Last Post: 27-04-2015, 09:44 AM
  2. TPMS - is it a dealer coding job?
    By rafletcher in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-12-2014, 08:12 PM
  3. Key cutting & remote coding help
    By david2 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-01-2010, 10:54 PM
  4. Remote Locking Coding
    By martinj in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-12-2007, 05:04 PM
  5. Remote Locking Coding
    By martinj in forum Archive posts
    Last Post: 11-12-2007, 11:24 AM
