Thread: Vw crafter timing ring/crank oil seal
  1. Vw crafter timing ring/crank oil seal
    Jul 2018
    North yorkshire
    Hi I’ve recently bought a vw crafter with issues, it’s a 2012 mwb 2.0 that goes into limp mode when you accelerate too hard and also has starting issues! It was plugged in and I was told it was the crankshaft sensor but in an effort to change it I broke the mounting, resulting in gearbox and flywheel removal and purchase of the tool to replace the crank oil seal that incorporates the sensor and timing ring. I’ve locked engine at tdc but cannot get the seal to align correctly, is there a difference in the crafter tool? I’ve tried moving the crank to the next tooth on the locking device but still no joy!! Any ideas folks? Cheers lewis
  2. Re: Vw crafter timing ring/crank oil seal
    1840 Post(s)
    Which engine code and which tool did you buy and I will check on ELSA for you tomorrow.
  3. Re: Vw crafter timing ring/crank oil seal
    Jul 2018
    North yorkshire
    Thanks for the response crasher, I’ve been looking at the different tools this afternoon and as you are correctly diagnosing I’ve got the wrong tool for my engine so looks like another investment in another expensive alignment tool��
  1. 1.4 TSI Crank Oil Seal
    By Bonneville in forum Leon
    Last Post: 02-10-2017, 10:31 PM
  2. Please Help BRE 2.0TDi Crank Seal Leak
    By Omnipresentdave in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-12-2015, 11:18 AM
  3. VW Crafter MWB - factory seal split/crack
    By Super_fish in forum The Commercial Range
    Last Post: 11-04-2015, 03:10 PM
  4. Front crank seal - anyone done it on a 1.8?
    By Last Triumph in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-02-2009, 09:31 PM
  5. Crank pulley seal oil leak
    By brauser rexel in forum Polo - Derby - Lupo - Fox
    Last Post: 06-07-2008, 04:07 AM
