Thread: 2.0tdi CR V-Belt tensioner replacement
  1. 2.0tdi CR V-Belt tensioner replacement
    Feb 2010
    lesta
    Hi all, I've got a whirring noise coming from the aux belt area. Can't really hear it on idle but noise increases with accelerator. I'm guessing it's the belt tensioner. Does anyone know if these usually fail and how easy it is to replace? Car has done 66k.
    Link below shows the tensioner. Bolt looks like it comes in from the rear of the tensioner but can see one on the front in the car.
    Assembly overview - poly V-belt drive with tensioning element and air conditioner compressor
  2. Re: 2.0tdi CR V-Belt tensioner replacement
    1837 Post(s)
    More likely to be the AC compressor, on the Golf 6 they are very unreliable.
  3. Re: 2.0tdi CR V-Belt tensioner replacement
    Feb 2010
    lesta
    Hi, my compressor is denso but it's not the one with the 3 bolts that has the issues. The noise is there even when the ac is not on so would this make a difference?
  4. Re: 2.0tdi CR V-Belt tensioner replacement
    1837 Post(s)
    Yes the Denso unit on the Golf 6 is the one we replace lots of, they are a constant drive unit without magnetic clutch. We had a lady in last month with a 2012 CAYC Golf 6 and she has been having nightmares with it. Over the last few months we have done one injector (which had been replaced before with what looked like a recon part) using a new VDO part, then a genuine VW high pressure fuel pump with full genuine timing belt setup and new Febi poly V belt with Febi tensioner, Febi alternator pulley, Midland Turbo turbo rebuild, genuine EGR valve and Sachs clutch/DMF plus a VW reflash update of the recall map using ODIS and eventually we managed to get it to idle smoothly and pull cleanly without sounding like a tractor. Then she came back with a front pulley noise which her husband was convinced was the new timing belt and it was the AC compressor so now that has been replaced with a new Denso unit as well and I have not seen her for a fortnight! It is not often I feel sorry for customers but they have been through the mill on a car they had only just bought from a relative....
  1. Aux belt tensioner replacement
    By Adman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-03-2023, 05:48 PM
  2. Question How do you change belt tensioner 2.0tdi
    By ian4455 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-05-2013, 11:52 AM
  3. How To 94 TDI 1.9 Timing belt tensioner replacement
    By wells01 in forum 80 - 90
    Last Post: 21-05-2009, 09:49 PM
  4. Fan belt tensioner replacement
    By Grant620 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-01-2009, 10:23 PM
  5. Alternator belt replacement (tensioner)
    By Neolithian in forum Octavia
    Last Post: 11-10-2007, 10:41 PM
